Hello all,
I am looking to buy a gps setup for my sds100 and see that Uniden is discontinuing the old setup and now offering a new setup. Does anyone have a recommendation on of I should go with the old setup of the new setup? Some vendors still have the old one in stock so I wanted to get some user opinions. Thank you!
First, a little background:
The original GPS (
BC- GPSK) unit comes in multiple parts, the receiver, the power/DB-9 cord and an optional
GPS Accessory Cable for handheld and HomePatrol scanners. It requires 12VDC via a cigarette lighter plug but does not power the scanner.
Later, after the BCD325P2 and SDS100's came out a fourth part was added, the
GPS Adapter Cable, this took the puck part and had a USB A plug for powering the radio AND GPS as well as a USB Mini plug to connect to the scanner.
When the SDS200 came out the GPS setup was greatly simplified with a new receiver in a square matchbox size package (
CB-GPSK) with a single telephone style cable. This GPS was powered by the SDS200 and is the same unit that is supplied with the BC885 CB/Scanner.
Uniden has introduced a Universal GPS kit, the
BC-SGPS that includes the same GPS receiver itself that comes with the SDS200, as well as an adapter box and a whole bunch of different cables: Power (Cigar plug), Mobile (for BCT15, 996 and 536's) Portable (436, HP1, HP2, 396 etc.) and USB (SDS100, 325) as well as the SDS200 phone style connector.
Comparisons:
The BC-SGPS kit is actually cheaper than the original setup even though it contains more stuff and connects to more radios. It does have quite a mish-mash of cables to go thru the adapter box (except for the SDS200).
While modifying your radio and inserting an internal GPS receiver is an option, it is kind of drastic and invasive IMHO. The problem with the external solutions is (again, other than the SDS200) that there is gonna be a bunch of wires and adpater cables strewn about and possibly coming loose. The new kit is cheaper and works for any Uniden GPS-capable scanner but potentially has more wires and devices.
For your SDS100 you would pay $80 for the new kit at the expense of an extra cable and adapter box. For $110 for the GPSK and Adapter Cable combination you have less of a mess.
