Okay...the latest in my techno-meanderings...went into win96...web import...imported talkgroups for area into block 1....then went up to Scanner tab..clicked uplaod to scanner (thinking that the channel apge I was on might upload....orange flash from usb serial converter showing upload...yet again, ooopsie...cleared channels...now reading:
0123456789
All Channels Locked....next?
To verify that any data is in your scanner at all, try going into Win96, File Menu/New Template
then Scanner menu, then download from Scanner...then browse the banks, and see if anything is programmed, and also if there are any lockouts...Let us know what you see there.. Usually that message appears when you have nothing in the scanner
Have you tried to manually enter a few frequency's in Win96, then try to upload them to the scanner
If all else fails, I would Re-initialize the scanner... then try again to download using Web Import
Initialize The Scanner
1. First turn the scanner OFF then back on again.
"Welcome To Digital Trunking" will display
2. Press the 0 button. "System Tests; Select Test; Exits if no Key Press" will display.
3. Press the number 1 button. "Factory Init; Erase Memory; ENTER if Yes; CL to Exit" will display.
4. Press the ENTER button. "Initializing; Clr Main Mem; V-Scan is OK; Please Wait" will display.
Wait until the initialization of the scanner is complete before turning it off. When the scanner has finished initializing, "M000" will display on the top line and "Bank 0 Ch 00" will display on the bottom lin
