APX Newest APX Impres II FW?
wgbecks
NE Wisconsin
Anyone know what the most recent Impres II FW is for the NNTN8845 Charger?
FYI,
The NNTN8845A SUC's are flashed using the NNTN8870A Fleet Management/Reprogramming Module (About $22 US) in conjunction with
the MSI Charger Reprogrammer program that's a free download from MSI. The reprogrammer tool downloads new firmware files directly
over the internet. No MSI account required.
N4KVE
PALM BEACH, FLORIDA
FYI,
Yes, he mentioned that. He couldn’t put the program on his laptop, meet me, & upgrade my charger. He could only upgrade the charger while connected to Motorola on the internet. That’s why we swapped chargers.
wgbecks
NE Wisconsin
This tool doesn't require a lot of bandwidth and would likely have worked using a cellphone Wi-Fi hotspot. Although the program does store
the firmware files on the PC, it does check the server for new updates. I am not sure if it will proceed with an update using a cached file without first contacting the server to check for new firmware releases.
Nonetheless, you accomplished your update by swapping chargers that is something I've done for friends having the earlier Impres chargers
requiring a connection to an Impres Field Programmer (IFP). I did like the IFP concept where you downloaded the firmware from MSI and then flashed the IFP that in turn could be used in the field without an internet connection. You could also reflash the IFP backwards with an older firmware version if needed to address a bug or compatibility issue.
