Hytera PD362i CPS ver needed for 5.01xx FW
k7dmk
I purchased a used PD362i on ebay. I have a couple of these radios now. This radio is a bit newer. My older HT's have FW that is 2.xx series. This radio has ver. 5.01.02.003. I have not seen FW 5.xx before, and can't read the radio with my newest CPS which is 2.06.xx. It was last programmed in late 2022. Anyone know what CPS I need?
Thanks.
wkredick
Waterford,New York,USA
CPS you need is the 5.01 version to match radios with FW version 5 radios. Pseudo Trunk.
Just finished programming 80 of these V5 units. I have to archive so many older versions for other customers.
k7dmk
Thanks. I found out about the so called "unified software" that looks at the radio when it's read, determines what version CPS is needed, and loads it. I purchased it from TARadio in Fl. and it worked fine. It did load the V5.01.05 CPS as you said. Ironically, I purchased another used PD362i from the same ebay seller, and the second one had the 2.0xx firmware that I was used to seeing.
wkredick
ok good. I forgot to mention the Unified Tool for pseudo trunk series. Version 5 FW the mfgr removed some capabilities for features available from previous FW versions. I learned it the hard way. Good luck on your endeavors.
arczieku
Hi, I have the same problem, I bought a CPS and after connecting the BD615 walkie-talkie, the program wants to update to version v5. Where can I download the update?
