NEXEDGE 48 Sys R254
mciupa
ELBOWS UP, CANADA
Moderator
I'm here a lot
Has anyone in the GTA come across this before? I was trolling for signals in the 460's and came across this. TAFL is no help location wise.
The frequency is 460.3125
GROUPS
NEXEDGE48, 254, 10101, 50, Normal, 3, 2024/12/10 17:07, ""
NEXEDGE48, 254, 10121, 50, Normal, 38, 2024/12/10 17:05, ""
NEXEDGE48, 254, 10131, 50, Normal, 6, 2024/12/10 16:54, ""
RADIOS
NEXEDGE48, 254, 10101, 10012, 50, Normal, 4, 2024/12/10 17:07, ""
NEXEDGE48, 254, 10121, 10148, 50, Normal, 0, 2024/12/10 15:19, ""
NEXEDGE48, 254, 10121, 10158, 50, Normal, 3, 2024/12/10 15:39, ""
NEXEDGE48, 254, 10121, 10165, 50, Normal, 8, 2024/12/10 16:40, ""
NEXEDGE48, 254, 10121, 10191, 50, Normal, 0, 2024/12/10 17:06, ""
NEXEDGE48, 254, 10121, 10192, 50, Normal, 9, 2024/12/10 17:05, ""
NEXEDGE48, 254, 10121, 10220, 50, Normal, 2, 2024/12/10 16:56, ""
NEXEDGE48, 254, 10121, 10230, 50, Normal, 7, 2024/12/10 17:02, ""
NEXEDGE48, 254, 10121, 10231, 50, Normal, 8, 2024/12/10 17:03, ""
NEXEDGE48, 254, 10121, 10233, 50, Normal, 0, 2024/12/10 15:43, ""
mciupa
ELBOWS UP, CANADA
Moderator
I'm here a lot
I found the voice frequencies for Site 8 (460.4375) and (460.5875)
It sounds like a trunk system for CN Rail on Site 8 - 460.3125 460.4375 460.5875
Site 7 frequency is likely 460.275 which would make that CN Rail MacMillan Yard.
Picture below is off of 460.5875
mjf
Toronto, Ontario
I'm hearing that same signal in west, central Etobicoke. The correct frequencies are: 460.30625, 460.43125 and 460.59375. I confirmed this with my IC-705 using the spectrum scope, 6.25 KHz steps and the 7 KHz filter. I confirmed NXDN RAN 8 with my BCD996P2. I heard voice on all three channels so the first one seems to do double duty as a CC and voice channel.
EDIT: taking a closer look, the frequencies are even a little off from those.
mciupa
ELBOWS UP, CANADA
Moderator
I'm here a lot
Running LCN Finder on my 536 returns CH ID of 81, 82, 83 for those frequenices.
I'm trying to find out where site 7 is. Choices are MacMillan or Brampton. Nothing heard for me yet for site 7.
mciupa
ELBOWS UP, CANADA
Moderator
I'm here a lot
Two 7 RAN's I found in the past are 461.1375 and 463.9875. Could these be R254-7 CH ID 71 and 72? Have some sleuthin' to do.
Brampton Intermodal Terminal​
FrequencyInputLicenseTypeToneAlpha TagDescriptionModeTag
159.810BMCSQCN007CN 7 OperationsFMRailroad
161.055BMCSQCN063CN 63 Yard SwitchersFMRailroad
460.6125BM32 RANHump 1Hump - TG 1NXDN48Railroad
460.900BM32 RANHump 2Hump - TG 2NXDN48Railroad
461.1375BM7 RANCN BIT 10102Terminal - TG 10102NXDN48Railroad
463.9875BM7 RANCN BITTerminalNXDN48Railroad
mciupa
ELBOWS UP, CANADA
Moderator
I'm here a lot
Today's run on LCN Finder yielded this:
Site Frequency Table​
CH IDFrequency
71463.9875c
72460.6125
73460.900
74461.1375
Works on the 536 with this configuration.
I see in the past, I logged talkgroup 10102 on 461.1375. That is the only talkgroup I haven't found recently. Only getting 10101, 10121, 10131 on both Malport and Brampton Terminals
  • Like
Reactions: mjf
