NH Feed
steele_lpd
Center Barnstead, NH
Great Feed! Covers a very extensive area.
Thanks Alex. At the moment the scanner is connected to a run of RG6 Quad-Shield coax and a mobile magnetic antenna about 12-15 feet off the ground. When I have the time, and extra cash, I will put up a better antenna on the chimney with better quality coax.
NYRHKY94
Brunswick County, NC
Hi Paul:
Nicely done! The sound is excellent. P.S. If you're using the BC785D for the feed, you would be able to stream the alpha tags also using some additional software.
steele_lpd
Hi Paul:
I've read some articles about streaming the tags but haven't had a chance to look into it. Is the software free and will it work with Windows Media Player? The main reason for the feed is so I can hear the fireground channel in my hometown when I'm at work. We're not allowed to download other software on the work computers (ie: WinAmp).
Livewire3286
Montesano, Wa
Windows media player wont show transmited tags. Winamp will
but I have instructions if you want them. Works with uniden scanners
