Niagara County Testing
ak716
'Merica
Heard Niagara county testing vtac and UTAC frequencies any info on them
National Interoperability (United States)
Most counties (who knows, maybe all to some degree by now) have NIO frequencies set up. Some have them set just as conventional, some have them paired to a TG on that county/region TRS (Monroe Co, for example). Previously, I've seen NYS awarding state interoperability grants, which have been used to expand NIO frequency coverage and capabilities.
I'm sure someone will likely know more than me about this, but I BELIEVE some (or most, or all, idk) have those repeaters set to off (or whatever it would be), and the county COML's will turn them on as needed, hopefully at the site that best suits the incident. Years ago, during the riots/protests/lawlessness in Buffalo, Erie County turned on one of the UTAC repeaters to enable interoperability among LE agencies operating in the city. At some point (I don't remember the duration), it was patched to Countywide Law/Police, or BPD Ch 1, or something like that.
The idea is to have band-specific interop frequencies that everyone should have (assuming they are licensed or have an agreement with a license holder, or whatever is recommended for your use) in place, so everyone who needs to talk can, regardless of where they're from. In theory, a firefighter from Central NY could deploy to Niagara Co for a disaster. That CNY agency wouldn't have access to the Niagara Co TRS on their radio, but they may have NIO frequencies, which they could use. So, whoever could hop on UTAC, VTAC, 8TAC (or whatever is being used), and voila, they can talk to local resources, or whoever they need to at that incident.
Erie County, last I knew, has/had V/U/8 CALL/TAC equipment setup at various sites in the county, for just such a purpose. Seldom used, but helpful when you need it.
Phoenix-23
Cheektowaga
They were using the countywide 1 one talkgroup and then testing the UTAC and vtac analog what was weird tome was they were using vatc and 8tac and 7tac I thought the county had apx900 uhf radios
ak716
'Merica
Niagara Co has a slew of various radios. The only APX900's I've seen have been associated with schools. I've seen Niagara Co fire agenices with APX4k's and NCSO with APX6k's (maybe 8k's?). NYSP obviously has 8k's, among various other radios. I'd imagine their OEM/ES peeps would have 8k's.
Makes sense, testing the V/U capabilities and patching onto a local TG, similar to what Erie Co has done in real-world situations for Erie Co conventional channels.
ThePagerGeek
Great overview.
This was part of the solution to the failed SWN project. Instead of building their own statewide system, they would use the local systems and fund the expansion of the national interop frequencies at the infrastructure level to enable operations from other outside agencies, as you noted. They would also fund county interconnects, both connectivity (microwave) and operationally (ISSI).
If the national interop channels are repeaters (not all are), they should be turned off until needed and can be controlled at the PSAP. You can use them as such, but a note should be sent to the state (OEIC) that you are using them.
Many systems (Monroe, Orleans, etc.) have the channels configured as voted simulcast, with no site selection at the dispatcher level. Some systems are site-specific. Erie County used them during the 2017 snowstorm. I'm sure there were others.
Also, as you noted, SELDOM used. I'm sure there are some counties where they have never been used.
Phoenix-23
Cheektowaga
Has anyone heard anything on the new conventional frequencies operation 1-5 or county talk around or know what they will used for
k2hz
Rochester, NY
Here is the info that was submitted about those channels:
"Regarding the conventional ops channels: the analog versions of Ops 1-5 are retained for worst-case scenario interop, but county radios are programmed for mixed mode, and are used in P25 mode primarily. These ops channels (in P25 Mode) have traditionally been used during multi-alarm operations that require tanker filling ops, RIT/FAST activations, or separate overhaul operations with multi-exposure fires."
They are not really new, just previosly unreported due to seldom used.
National Interop channels are not listed in RRDB for each county since they are a nationwide standard and only used in emergencies requiring Interop with outside agencies. If there are trunked system TGs associated with specific conventional Interop channels they will be in the trunked system TG list if the information is available.
Phoenix-23
Cheektowaga
I guess I took the long way to ask what conventional channels are worth adding to the radio
k2hz
Rochester, NY
In the RRDB the note on the Niagara County Fire conventional subcategory listing says:
"Dispatch 425.4625 is a simulcast of the trunked system talkgroup 101. Primary operations now take place on the trunked system, however the UHF frequencies are retained for backup purposes in either analog or P25 mode.
Niagara County Public Safety System
Project 25 Phase I
Primary Fire communications are on this system.
These RRDB conventional page notes and links to associated trunked systems are there to make users aware when primary operations are now trunked and link to the associated trunked system.
Phoenix-23
Cheektowaga
Now I see it they are the ops from when they first switched to UHF thank you
APX_Radio
New York
When did Niagara County change these analog channels to mixed mode and start using them as P25?
Phoenix-23
Cheektowaga
This is what I have for the old channels do they still use ( EMS AIR ) I thought I heard it used recently
If they use does anyone have the NAC for the P25 side
k2hz
Rochester, NY
The NACs are all in the RRDB listing:
FrequencyInputLicenseTypeToneAlpha TagDescriptionModeTag
425.4625 WQCC455BM179.9 PLNC FD DispatchDispatchFMNFire Dispatch
425.3125 WQCB737M123 NACNC FD Ops 1 DOperations 1 Mutual Aid TA_DP25Fire-Tac
425.3125 WQCB737M152 DPLNC FD Ops 1 AOperations 1 Mutual Aid TA-AFMNFire-Tac
425.3375 WQCB737M124 NACNC FD Ops 2 DOperations 2 Mutual Aid TA_DP25Fire-Tac
425.3375 WQCB737M174 DPLNC FD Ops 2 AOperations 2 Mutual Aid TA_AFMNFire-Tac
425.3625 WQCB737M125 NACNC FD Ops 3 DOperations 3 Mutual Aid TA_DP25Fire-Tac
425.3625 WQCB737M223 DPLNC FD Ops 3 AOperations 3 Mutual Aid TA_AFMNFire-Tac
425.3875 WQCB737M126 NACNC FD Ops 4 DOperations 4 Mutual Aid TA_DP25Fire-Tac
425.3875 WQCB737M343 DPLNC FD Ops 4 AOperations 4 Mutual Aid TA_AFMNFire-Tac
425.2875 WQCB737M051 DPLNC FD Ops 5 AOperations 5 Mutual Aid TA_AFMNFire-Tac
425.2875 WQCB737M127 NACNC FD Ops 5 DOperations 5 Mutual Aid TA_DP25Fire-Tac
425.2625 WQCB737M051 DPLNC FD EMS/AIREMS/AIR OperationsFMNEMS-Tac
424.0875 WQCC454M7F3 NACNC NT/LK FD TANT/LKPT Fire Dept TalkaroundP25Fire-Tac
429.0875 WQCC454MCSQNC Hazmat TAHazmat TalkaroundFMNFire-Tac
APX_Radio
New York
So someone read a fire radio and submitted a database change based on a personality that exists in their radios but are not tied to any zone channel assignments (except for LFD/NTFD)? The personalities are not mixed mode. The analog channels are tied to an analog only personality, the digital versions are tied to a digital only personality.
k2hz
Rochester, NY
That is the impression I got from the submission is that there is a mix of legacy analog radios still out there but the current issue radios are digital. There was other info about the actual limited use of these channels vs the trunked system so I had to list all channels as could be either digital or analog based on the radios in use.
APX_Radio
New York
Fire is a majority APX4000 with some 6000, 8000 and XTS all of which are analog and p25 (and trunking of course) capable. A majority of mobiles are still XTL. The fire ops channels in the radios that are assigned to channel selector positions are analog only with the exception of the NTFD/LFD ops channel.
The digital channels that someone submitted are in the radios but not assigned to any channel selector slots. There are no plans in Niagara County to migrate fire ops channels to digital at this time.
I am just a nobody but IMO I think those ops channels should be listed as analog only.
