Niagara Falls Fire - problems with system
Gator596
Niagara Region - Canada
I've downloaded this system from the DB a couple of times and have been unable to get it to run. I see the live feed provider in the area says it gave them problems too.
Has anybody out there got any suggestions on how to make it work?
I am running Freescan to a bcd396xt.
Thanks,
ibagli
Ohio
You have to program the frequencies as conventional and just lock out the control channel (I'm not sure if it rotates or not; if it doesn't, just don't program it). No scanner can track MPT-1327 systems, so it's impossible to separate the Fire Department from any other users. There's also an annoying data burst at the end of each transmission.
Saint
Fort Erie Ontario Canada
problems
Your correct ibagli, all you can do is download all the frequencies for this system and then start scanning them with your scanner, when your scanner locks onto one of the control channels just lock out that frequency so the scanner won't stop on the frequncy again.
The fire department is in the process of getting off this system and getting there own frequencies and this is in progress as I send this post.
Steve
Steve
firefgtr
Welland, Ontario Canada
I understand this July is when they want a new common dispatch frequency and 2 working tac frequencies, as well as new voice pagers for the volunteers and on call fire prevention
Saint
More Information
This is the last information I found on the new system for the Niagara Falls Fire Department and Frequencies
Steve
Also you can get all the information on this subject on this link, go down to VHF Simulcast, Conventional, Voice Radio Communications System -Niagara Falls Fire Services and all documents will be there.
Steve
http://www.niagarafalls.ca/city_hall/departments/clerks/supply_and_services/tenderArchive.asp
