NJSP Question
Anyone getting two TGID's on the NJ 800MHz system, with one transmission?
My BCD396XT is getting 35799 & 35152 simultaneously.
Skypilot007
Medford, NJ
Another Question...?
Anyone in the Burlington county area around Medford notice that the signal strength from the central site has gone way down. I've noticed this since yesterday afternoon. Other things I monitor with the same antenna are coming in fine, just troop C control channel signal has dropped significanty here. My portables can't lock onto it at all. Strange....
GTR8000
NY/NJ Database Guy
BEE00
35152 is the Executive Protection Unit talkgroup, and 35799 would be the status bit +7 for 35792 5-COMM Dispatch South, which indicates a Multi-Select by the dispatcher. Basically, it means the dispatcher was (probably) intentionally transmitting on both talkgroups at the same time. That being said, you should've seen 35152 and 35792 if your Status Bits is set to Off/Ignore, you should've only seen 35799 if you had Status Bits On.
GTR8000
NY/NJ Database Guy
BEE00
Status Bits should be set to Ignore.
It's the marine police TG's. They must be doing it on purpose, because it happens no matter what the setting is.
adamr368
NJ
Those talkgroups are usually patched together...
