NMN6228c mic
Pottstown pa
I picked up a NMN6228c mic i am trying to figure out what the switch dose on the top of the mic. I know there an antenna port and I know it has noise cancellation but I can’t figure out what the switch dose.
K2NEC
39A
Well, its intended for the Jedi series radios. There's a port on them on the side connector as well as the coax connection pins that goes up to the antenna port on the mic head. Otherwise it's a pretty self explanatory mic
Pottstown pa
Well, it’s intended for the Jedi series radios. There's a port on them on the side connector as well as the coax connection pins that goes up to the antenna port on the mic head. Otherwise it's a pretty self explanatory mic
I have a set of ht1000s I am using them on. Ok I just wanted to make sure i wasn’t missing any features they came with.
Pottstown pa
Is the antenna on the radio disabled when the mic is on it?
K2NEC
39A
Yes,  somewhere I still have a picture of my MTS2000 with no antenna on it just the mic with an 800 stub. Worked well actually
MTS2000des
5B2_BEE00 Czar
Most HT1000s had an RF switch on the side, but 2 channel models made during the later period do not actually have the RF switch on the RF board. You can easily tell by putting the radio in RX mode (on say, a weather channel or keyed repeater) and press the plunger with a pen or other dull pointed object, if the receive drops or goes away, you have an RF switch, if not, the RF board has a factory installed jumper. (This applies to 2 channel HT1000s only)
