BCD436HP/BCD536HP: no batteries
shew
PIERRE PART, LA.
I have 2 436..one will stay home and the other will be mobile...the one I want to use as a mobile..will it lose all it memory if I leave the batteries out for an extended period of time....I won't use batteries while it is mobile
Voyager
Define "lose memory" - no programming at all?
Or if you are asking if it will lose the memory, no, it should not. It will lose the clock settings after a week or so without power.
Also, some functions such as recording will be disabled.
jonwienke
More Info Coming Soon!
VA
Don't run a 436 without batteries. It will disable recording and other functions. Also, if the power cable jiggles loose, you can corrupt the memory card and temporarily brick the scanner until you reformat it.
jonwienke
VA
Nothing wrong using a 436 as a mobile, just keep a set of batteries in it.
