No Ground Plane 700/800
billyfromhill
Does any manufacturer make an NMO 700/800 no ground plane antenna? Looking for something to cover approximately 760-870 MHz.
merlin
DN32su
700/800 MHz needs so little ground plane it is hardly worth mentioning.
Adjustable antennas like PcTel or MaxRad, I found a better SWR with no ground plane, simply by lengthening the rod by 1/8 or 3/16 inches.
This applies to transmitting at 900 MHz amateur.
A 5 inch diameter piece of sheet metal with the NMO mount centered would be a good ground plane.
