No receive after 5 seconds unless channel change
dickie757
Wired
Out of range
I had a batch of CP100ds VHF all identical to program for a customer...got a call explaining a weird behavior where a (single) radio can transmit then receive if end of transmission was at most 4 seconds ago. If 5 seconds, the radio will not show any sign of activity.
I went to the customer and proved it for my self. Then, I cloned a known good radio into problem HT. Same behavior.
Some facts: analog with DPL, but brought it back to the shop and went csq for test. No change. The test transmitting radio was still tx'ing dpl, but i dont think that matters. I was going to strip dpl from tx, but got distracted ran out of time.
Also, if channel is changed, then changed back to original, the "timer" resets.
Not sure how long it has been acting up, but I programmed the batch first part of November.
