SDS150: No reception on assigned channels
fyrboy
here
I reprogrammed my 150 three times, with tweaks each time, with Sentinel and remain unable to receive any trunked units unless they transmit on their respective dispatch channel. City & county use P25 - one’s Phase 1, the other’s Phase 2. All are in one FL. Thanks for the help.
Chris0516
Pittsboro, North Carolina
Have you enabled the Service Types?
jasonhouk
Uniden AlphaMan
Uniden Representative
Marion, Ohio
Could you please provide links to the systems you are trying to monitor, along with the specific area or location where this monitoring is taking place?
This appears to be a question typically found on the Florida forms.
fyrboy
here
dmfalk
Eureka
Let's try this: For those talkgroups, go into each and change NAC to "search", and see what happens.
fyrboy
here
Just received a county fd-dispatched channel. Thanks very much.
dmfalk
Eureka
Sometimes, the NACs change from what's in the database, and can often be the culprit, after ensuring that service types are already engaged. Glad this helped!
fyrboy
here
Thanks again. I didn't know NAC from A-B-C, and barely knew service types "matter." Now, how do I get it to stop scanning, then re-start?
dmfalk
Eureka
I assume you mean a hold on the particular talkgroup, in this case.... See at the bottom where the words align with the three keys immediately under the screen? Those can hold onto a system or the channel/talkgroup you're currently listening to. You hit the button under which hold you want. This would most likely be the rightmost one. Hit it again to resume scanning.
fyrboy
here
Yep. Thanks again.
dmfalk
Eureka
Here's a video that explains holding on a channel or system on an SDS scanner. (It's for the SDS100, but works the same on an SDS150.)
