Noise Filter
cubspack
Council Bluffs, IA
Would it help to get a noise filter if im getting interference from a casinos transmission on my pro 197? I was talking to someone and they said that may help. If so what should i look at?
W6KRU
Vista, CA
What frequency is the casino on and what frequency are you listening to when you hear the interference?
W6KRU
Vista, CA
Wow. you must be really close to the casino. I don't think a filter is going to work. The Harrah's frequencies are interspersed with the ORION frequencies. A filter that attenuates one is going to affect the other. An 800 yagi might help but I'm not sure. Maybe someone else will have another idea.
cubspack
Council Bluffs, IA
Yeah im right across the golf course from them. When i take the scanner in the car and drive around its fine but when i get close it starts in again.
WA1ATA
Fairhaven MA / San Jose CA / Kihei HI
Try an attenuator. This will help if the casino is overloading your receiver front end.
What happens if you remove your normal antenna and have just a tiny bit of wire? Do you still have enough signal from the desired station to receive it?
cubspack
Council Bluffs, IA
I messed around with it alot lastnight and i turned the attenuator on and it helps alittle. I still get some but not as bad.
