noot NP11 BT earbuds
stevez97
Myrtle Beach, South Carolina
These earbuds paired with my G4 V1.10. The beeps are present, but for Amazon Prime $16...they're not bad.
That's excellent! How is the volume level? My Plantronics headset pairs, however, I have to turn the volume up on the G5 to 95 to 100% of maximum in order to SOMEWHAT hear the audio in the headset. Please let us know if you are experiencing audio levels that surpass mine.
Thanks!
gcopter1
Winter Park, Florida
eorange, are you able to control the volume with the earbuds?
For example, set the pager to the max volume, then use the volume control on the earbuds to a suitable listening level?
blackbelter
I will be purchasing this tp pair up with my new G5. The audio on the unication BT head set didn't work well
blackbelter
Just received my NP11 BT head set . So far this is the only BT head set that works and paired immediately with my G5 . I keep the volume between 60 and 65 and it sounds good in both ears . The BT own volume control has no effect . I think the EDR universal compatibility are the key in pairing .
Thanks for the tip .
blackbelter
More about the EDR ( Enhanced Data Rate):
Bluetooth 2.0+EDR and Bluetooth 2.1+EDR are specifications for short-range wireless data exchange. Both Version 2.0 and 2.1 support EDR (Enhanced Data Rate), a faster PSK modulation scheme capable of transmitting data 2 or 3 times faster than previous versions of Bluetooth.
