Unication vs Motorola
KevinC
The big K
Super Moderator
I'm everywhere Focker!
Yes like trying to switch zones (well of anything else for that matter). I purposely leave a blank knob position in every zone due to this. I tried just unscrewing the antenna but a couple of times I had such a good signal it still kept receiving. I agree, I wish there was a way to do anything while it was actually receiving.
Yes, I have a blank knob position just for that purpose as well.
K9KLC
Southwest, IL
1/4 to 1/2 mile. Really depends on the ERP of the sector, antenna down tilt and rad center.
Ok thanks, ya I'm about a mile and haven't noticed anything odd on the Unications. I'd have to get with someone and get the ERP, down tilt and Rad information. Again, thanks.
Ravenfalls
I carry 2 Unication, some carry more. Can't go wrong with G5.
No de sense in my Unication.
Program a blank ch per zone, user preference. I think it's a waste of a channel.
Commercial radios, easy to miss a step. When the PTT is accidentally pressed, radio can only be used for parts.
User will easily loose 3/4 of the cost when selling the parts.
peq387ab
West Central MN and Eastern ND
I have been using Unication G5 pagers 700/800 & VHF since early 2019 when I made a migration for our department to switch from the Moto Minitor pagers. Since that I can say that I love these units and they work great for conventional VHF paging and 800 mhz scanning of our talkgroups.
I have noticed the reception does great into simulcast areas and even the vhf range for paging was increased in audio quality on those fringe areas away from the paging control sites.
Fast forward to 2024 and “most” other departments are using them as well.
I liked it so much I purchased a 2nd one a couple years ago to use personally.
The Unication programming software is easy to use. And it’s a great “portable scanner”
krokus
Southeastern Michigan
I'm a bit late to to the party. The Unication can scan more than one system, but not at one time. IIRC, one system per zone.
Brettame5
Side-by-side with my work Motorola and my Unication, they perform the same. I am a system administrator and I have the keys - to program my department radio or inhibit a rogue radio.
The two greatest things to have happened to scanning are the Uniden SDS family of scanners and the Unication G-series of digital pagers.
Unication’s ability to follow a trunked radio system is equivalent to Motorola/Harris/Bendix King. I know because I have/had all three.
Only scans 64 talkgroups? Add a wildcard and you can have it all. 🤪 In the real world, I only suggest 10-15 talkgroups but YMMV.
What do you mean by wildcard?
Hit_Factor
Saint Joseph, MI
For many entries you can enter FF for the value, this tells the pager to accept anything. I have used it with site ID e.g., "Wildcard FF FF", System ID "FF". For talkgroups using the "Talkgroup Monitor" means listen for all TGs. Whereas Talkgroup Scan means listen to only the TGs specified. This is a fairly common question, searching this forum should give lots more info.
Brettame5
Is it possible to put more than the 64 channels in the scan or monitor modes that way I don’t get random numbers? Or have the entire system in a monitor?
Hit_Factor
Saint Joseph, MI
No, sorry. Those are not random numbers, they probably defined in the DB for this TRS. ;) Talkgroup Monitor is the equivalent of all TGs available on the site, not the entire system. That's a subtle nuance.
I suppose you could have an entire system on one knob, then talkgroup monitor would allow any TG. This could be useful in unfamiliar territory.
