Hi Trip,
Sorry I didn't follow through on getting back to you before.
I don't know specifically how the Pro2096 is programmed, because I use a BCD996T, but the way (I think) it works for me is as follows:
First you program a system that's set up as a Motorola TypeII/P25 type format. Within that system, you set up different sites (I think of each site as being a certain transmitter...so I have one site named "Ester Dome", "Birch Hill," "Eielson," etc.) You can find a list of these sites at
http://www.radioreference.com/apps/db/?sid=2447 -- the FNSB ones are between 201 and 222.
Now, on the 996T, all I have to do for each site is look at the list I linked above, program in the control channels for that site, and set the base frequency to 136.00 and a step of 12.5kHz. Then, I set my scanner to "ID Search," and it picks up transmissions All of the transmissions in the P25 system have a talkgroup ID assigned to it, which can be found on that link above. My software logs the IDs of all the talkgroups that pop up, and then I assign names to them. So, If I'm scanning, and a transmission with an ID of "23102" comes up on the Birch Hill site, that's the Fbks Police Dispatch. I believe that the data sent on the control channel at the beginning of the transmission includes the frequency the comm is being assigned to, and my 996 then hops over to that frequency to listen in. So, getting back to your original post, Fairbanks fire dispatch's talkgroup is 23416, Tac2 is 23417 and Tac 3 is 23418.
Again, I am really new to this myself and so I could be completely wrong in my explanation, so if I am, hopefully someone can correct me so I can get myself fixed up
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
. Also, I don't know anything about the Pro2096, and they mention in that page I linked to above about a Pro96 multitable setting for P25 systems, so I don't know if that makes a difference for you. But it sounds like, to my ignorant ear at least, that maybe you have the right frequencies programmed, but not the right talkgroups. I've never caught Healy or Tok on the ALMR system, but at least in downtown Fbks, I most often hear fire dispatch, Ft WW, AST, FPD, the MACS bus and the FNSB Park Rangers. I know UAF PD is on a conventional system.
Anyhow, I hope this helps some rather than making things more difficult -- digital scanning is a huge learning curve (for me at least) -- VERY different from the shortwave DXing I'm used to!
hi Guys
well i'm still looking for some of the freqs. that i used to have but can't locate some of them.
I do catch healy & cantwell troopers some i am still looking for the tok & delta freqs.
I've tried to down load for the R.R. site but I must have a wrong setting because i get nothing and the channels i do have i entered manually and do get alot of traffic but alot of milatary & D.O.T with some transit.
I have the pro 2096 with the comp cable to download so any help as to programming would help.
THANKS
