Not connecting
mws72
Quad-Cities (IA-IL) USA
The other day while I was monitoring a system. I heard the computer sound an disconnect. After a bit I determined it was the Blue Mark 2. Since then I have tried several times to get it to reconnect and run, but no joy. When I am trying I can see the power led on, TG is flashing as is the sig. led. Watching the list of connections I can see the various devices when I disconnect and re-connect the BlueTail never shows up.
Cheeseburgers
have you tested Bluetooth connectivity? Just to see if the unit still works?
dispatchgeek
Control channel goes "brrrrr"
Between the cornfields and the pastures, Michigan.
I've started having this issue as well with my P25RX. I can load the roaming table and TG List in file in BTConfig, but as soon as I power cycle the thing it defaults to it's own frequency and a single TG in the TG table. It also has the two LEDs flashing rapidly.
dcr_inc
Not an EXPERT !!
Delta, Pa
Post your questions on:
This is where Todd is available for direct help.
He has been banned from RR. He is still in business and supporting the entire P25RX line
