Not receiving any reception
dvstacy
Hi. I recently bought a Uniden BC125AT scanner. I’ve taken it with me several times on the highway but all I hear is static when it stops on a frequency. I haven’t heard anyone on CB, police, etc. I live in Ohio. Did I buy the wrong scanner?
belvdr
Most law enforcement would be on MARCS, a P25 trunking system. Your scanner cannot decode those signals.
Whiskey3JMC
_/|\_Surf's up, Happy DX!
Simulcastylvania, TE
Hi & welcome to the RR forums:
At the very least you'll need a scanner that can trunk track P25 Phase-I systems. See full list here. If simulcast is an issue in your area (Looking at Ohio MARCS there are a few simulcast sites) then I'd highly recommend the Uniden SDS100 since simulcast distortion may be an issue
iMONITOR
Silent Key
S.E. Michigan
Did you program it? Or are you using the Search mode?
dvstacy
I'm using the search mode and trying to scan whatever frequencies came with the scanner. As you can see I'm new at this. :(
iMONITOR
Silent Key
S.E. Michigan
That's most likely the problem. You need to program the scanner for the frequencies and services in your area that you want to monitor.
dvstacy
OK thank you. I will have to take it somewhere to have someone program it for me. I don't want to mess it up. Thanks again.
belvdr
Again, most law enforcement are on MARCS. Your scanner won't decode P25 nor can it scan the frequencies MARCS uses between 700-800 MHz.
dvstacy
OK, I now understand. Is there another handheld that will work and decode MARCS and P25? If so I'll try to sell mine and get one that will decode MARCS and P25.
belvdr
The only options for simulcast are:
Unication G4 or G5
Uniden SDS100 or SDS200
For scanning on the go, the SDS100 is likely the best, with the GPS option.
Swipesy
Northern Ohio
If you are interested in listening to Military Air and trains in Ohio keep the BC125 for that. For police and fire most of Ohio is now on trunked radio systems and you are going to have to spend some serious money on on digital trunking unit. You are looking at $600 + for the updated scanners and $400 + for the older Whistler/Uniden models.
dvstacy
where are you located?
Toledo, OH
Ok, thanks for the info!
