It could be several things. The reply of try a NOAA weather channel is a good choice of a strong on frequency test. And sometimes an alternate channel (one farther away) is a good test. Most of these scanners, weather monitors, two way radios use a 450Khz second IF filter that goes bad causing no or very weak signals. Some use a Wideband version filter and a Narrowband too. There are several models with various pinout configurations. LT450FW is a common wideband 25Khz filter. Also there is the Discriminator circuit coil some have... near the second IF filter it can be adjusted for clear sounding audio on a strong NOAA signal if you can recieve one. Don't go crazy adjusting... it should take less than a half turn in either direction to see an improvement. I have personally realigned dozens were the scanner couldn't scan because the misadjustment throws off the DC squelch voltage used for scan detection. Remember where the coil slug was set before turning, so it can be set back to that spot if no improvement. Also there are 455Khz versions of second IF filters, not interchangeable.(5Khz difference).
