LynxVortex
- Joined
- Jan 31, 2025
- Messages
- 6
- Reaction score
- 0
Hi guys, I recently got a Kenwood NX-3300, and I’m working on a small personal project. I also have NX-800 and NX-820 radios, and I’m trying to build a custom cable/system to link them together and make them behave like a small network. The radio(nx-3300) programs are perfectly fine with the original KPG-36X cable, so I know the radio itself is okay
Now I’m trying to access the radio through the accessory connector directly, using jumper wires (TXD, RXD, GND) and a CP2102 USB-TTL adapter, but I get absolutely no communication. What makes it even more confusing is that I’m seeing weird voltage levels on the pins
TXD pin sits at about 5.49 V
RXD pin sits at about 3.19 V
So this clearly doesn’t look like a simple 3.3 V TTL UART. This makes me think that the KPG-36X cable is not just a basic USB-TTL cable, and that there is some extra electronics or some kind of enable/handshake going on. I’m not looking for software, I’m just trying to understand the hardware interface.
My questions:
Does anyone know what’s actually inside the KPG-36X? (I found one on the Internet, figure 8 in the photos. It looked like a simple UART and USB converter circuit to me.)
Is there some extra pin or signal needed to put the radio into programming/accessory mode?
Has anyone here ever built a DIY KPG-36X?
If yes, what was the trick that made it work?
Also, I’ve seen some third-party cables that seem to only use 3 pins and just a USB cable. How do those work?
Any info, measurements, or experience would be really appreciated. Thanks!
My questions:
