RX list?
under DMR, group list, there is a box called GID SCAN, this is the ad=hoc thing as RX LIST 1 (and all the groups in that list) <mother M thing>
Digital monitor? Not like a scanner, so I don't think this is what you looking for,.
Came across this - sounds similar to kd4efm's note but more detailed from VA7TD:
Kenwood NX-5000 Series multi-mode digital mobiles - CQCQ.ca - Canadian Amateur Radio forum Canada - Canadian Ham Radio forum Canada (yea, cross-posted but credited source...)
"You can enable "promiscuous mode" for DMR monitoring:
Under DMR - Group ID List, create a new talk group. Under ID, enter "ALL". Name the talk group something descriptive, such as "ALL CALL".
In your DMR system, create a new Personality. Set the Slot to "Auto". Under DMR - Selcall on PTT, select "Group Call". Enter the new ID List Number that you just created above. The ID will auto-populate to "ALL" and the ID Name will auto-populate to "ALL CALL" or whatever you called it. Check the Group ID Scan box. Uncheck the Dual Scan Direct Mode box if it's checked.
Add the new Personality to the Zone where you want it to appear."
This suggests that radio accepts the text "ALL" to allow decoding of any possible DMR talkgroup...or is it just limited to those in the Group List or even created in the radio?
Still, as KD4EFM noted, it is unlikely to display Slot, TG and CC like pure promiscuous mode.
Greg
