NX-5000 Series, Q&A, Info, and details
03msc
RF is RF
The Natural State
Has anyone else who uses the audio recording feature noticed SD card corruption issues after a while? I find after a few months I start getting "SD CARD ERROR" on screen and have to re-format the SD card in order for recording to work again.
The cards are typically still perfectly readable in a computer, but the radio stops liking them and won't continue recording until a format. I'm going to switch over to an A1-rated card to see if that makes any difference.
This is on an NX57/5800 combo setup on FW 4.32
Could it be when the card gets full, maybe the radio is liking the need to overwrite?
W3AXL
RF Engineer
Indiana
Still 12/16 GB free on the card so that's not it.
My current theory is the cheap samsung SD card I was using couldn't handle the high write cycles that you get from constant recording. Hence trying an A1 rated card. We'll see if that helps at all.
03msc
RF is RF
The Natural State
OK, yeah that was going to be my next question was the card quality. Give it a try and let us know after awhile how it's going.
RRR
OFFLINE
USA
I would gladly pay for an option / option board, like Motorola radios can accept, that enable me to hear everything on a DMR channel I am monitoring. Makes no sense why DMR is setup so you have to have so many things lined up just to hear only what the radio allows you to hear on the channel, v/s NXDN, where you hear everything, unless you enable a RAN and / or a talkgroup to only monitor that.
RRR
OFFLINE
USA
This has nothing to do with stealing technology.
I have DMR Mototrbo radios, and DMR Kenwood. I have an option with my XPR series to install a board that will pass all audio from DMR. I do not have this option on Kenwood DMR, but I would like to have it.
I was hoping somebody would know if there may be a way to accomplish this with my Kenwood.
Could it be Kenwood owns NXDN and Motorola owns DMR?
Kenwood does not own NXDN. NXDN was developed by Icom and Kenwood and there's a few others that support it. Kenwood makes and sells a lot of DMR gear.
Same with DMR, it's defined by the European ETSI standard and many companies make DMR radios. Motorola just has a way of taking a standard and suddenly making it proprietary.
buddrousa
My thoughts were when you own or develop a standard you keep more options for yourself. That is why I posted as a question.
I also have NX5200 and NX5300 as our Department is looking to go fulltime DMR as DMR is being used in areas around us.
Oh, got it.
Yeah, I haven't seen Icom or Kenwood do that. Icom only did 6.25KHz NXDN for a while, but Kenwood did 6.25 and 12.5KHz NXDN. Eventually Icom came around. Both have shared the trunking protocols, Type C and Type D and it's possible to make an Icom radio work on a Kenwood trunking system and vice-versa.
On the other hand, Motorola bastardized some of the DMR Type3 standards and adding their own features that locked you into Motorola radios. As Motorola loves to do.
As for the DMR deficiencies noted above, I'm not totally clear on the request, but when I've looked at similar things in the past, it's often a ham radio user expecting ham radio functionality on a LMR radio.
ramal121
Lots and lots of watts
Calif Whine Country
You can disable ID filtering and listen to any ID. The channel will still follow color code and time slot however.
Personal > Personal Features > Open Voice Channel Mode
Open Voice Channel Mode (Transceiver Settings > Personal > Personal Features > DMR Conventional > DMR)
When the transceiver receives a signal with OVCM applied, the user of the transceiver can hear the conversation even if the IDs do not match.
RRR
OFFLINE
USA
Thank you for that, Ramal121. I am still learning DN1. I know well I could get a scanner and monitor all I want, but this is exactly what I was looking for. This is for business use, and unless we start getting interference from another DMR user, we won't be changing color codes.
When you state "ID" do you mean Talkgroup ID, or User ID?
W3AXL
RF Engineer
Indiana
Has anyone managed to get a good set of audio settings for better analog TX audio? I recall a year or so ago someone posted settings that people said made things better but I can't find that post now.
Even on the latest firmware, TX audio in analog mode still has the same issues it had years ago. Low volume, no compression/companding of any kind, and a high frequency rolloff that sounds "muddy" for lack of a better word.
Robert721
Klein, TX
Is there is a pdf programming guide for the KPG-D1? I'm waiting on radios to ship and would like to read up on the software.
W3AXL
RF Engineer
Indiana
Well for those curious, I went ahead and analyzed the various mic type settings to see if there was any appreciable difference.
Looks like the only mic type that makes any real difference is mic type 7, which boosts mic sensitivity substantially and adds more response to the high end of the voice spectrum. This setting is meant for the KCT-73MIC external mic kit, which likely has a lower output amplitude.
What's interesting is that there's seemingly no difference in the response curve between any of the other mic types.
W3AXL
RF Engineer
Indiana
I thought the audio settings only affected digital and not analog. Is that not correct?
I believe microphone type is one of, if not the only, setting that actually impacts analog. And as shown above, there's really only one option that makes any noticable difference.
