NX-5200 Scan Issue
CVFD-69
cvfd69@ymail.com
I recently purchased an NX-5200 and got it programmed. The only issue I have, is that when it is scanning and receives a transmission, it does not revert back to the selected channel. Is there a fix for this, and I’m just simply looking over it?
Josh
Auburn Hills, Michigan
Is there a fix? It's a programming error at worst. I don't have the software in front of me, but under scan, you'll want to be sure Revert Channel/ID is set to "selected" or "selected + talk back". Default is "last called", that way it goes back to that channel after scan resumes. Otherwise it will live on the last landed channel until another channel stops the scan.
-Josh
That's 100% a programming issue. Take it back to the person that programmed it. It's not something you can fix without programming software and cable.
CVFD-69
cvfd69@ymail.com
-Josh
That’s how I currently have it programmed, and it still continues to display the last channel that received something.
The KPG-D1N gets a bit confusing with this part. You will need to check in two places, depending on exactly how your radio is set up:
Under "Zone/Channel", select "Zone Edit" for which every zone you are scanning in.
Make sure "Revert Channel" option is set to "Selected" or something that includes selected.
Sounds like a Priority Scan would be a good option for you. Set up your Priority Scan to use "selected" channel, which will take you back to whatever your channel/group knob is set to when the timer expires.
Under the "Scan" settings, "Scan Information" tab, there's a bix you can check for "Selected Channel Scan" that may also give you what you want.
The software is challenging, so using the help files can be useful.
CVFD-69
cvfd69@ymail.com
The “selected channel scan” was what I needed, thank you!!!
