NX3300 Consecutive Write W/O overwriting IDs or Alias
70cutlass442
I have a fleet of 170 NX3300s that need to be updated. I need to be able to program each radio with a new file while leaving both the radio ID and the Radio Alias alone. I have played with a few different check boxes but am not quite sure what I need to do to accomplish this.
70cutlass442
Unchecked overwrite own ID.
That did it. Do you know if there is a better cable to use that doesn't go so slow? I am using an amazon USB cable and it takes between 3 and 7 minutes depending on what I am doing.
I use the Kenwood KPG-36XM with my NX-3400's. Loading my trunked system codeplug takes about 30 seconds.
tweiss3
Is it time for Coffee?
Ohio
Are you 3400s the two prong or multipin connectors, that makes a huge difference. I suspect the OPs are two prong.
NX-3400 = 14 pin connector.
NX-3420 = 2 pin connector.
NX-3300 = 14 pin connector.
NX-3320 = 2 pin connector.
OP stated he has the NX-3300.
KPG-22UM is the correct cable for the NX-3x20 models.
KPG-46XM is the correct cable for the NX-3x00 models.
AM909
Radio/computer geek
SoCal
Do I need the KWD-3002BT license for each NX-3300 to program it via Bluetooth?
kd4efm
EL98 Florida
Ditto, yes. each radio for BTSPP requires the license, exception is mobiles with the KCH-20RM head.
Otherwise, across the board, it is an add on option to all the NX-3k, 5k models.
