Sentinel: NXDN ONQ
Torontoteamone
Spoonfed
I want to add more sites for the ONQ system. I put the sites in Sentinal, but for some reason Sentinal didn’t add it to system. I can upload, so I am doing it manually. The LCN are a higher number then the other trunk system. Is it okay if I put the LCN in while I am creating the site?
gary123
Wrong forum :( OnQ is a Ontario Canada system. Please post the updated information there. Thank you.
The tech forum is for discussing technical issues or fixes for all Uniden products.
Torontoteamone
Spoonfed
the Mod moved it here
Torontoteamone
Spoonfed
What I want to hear on the system is the school busses and I seen there a tow truck company ad well I’m just trying to figure out the best way to program it with the LCN or fouce to write database if anyone has any ideas
mikewazowski
Forums Manager
Oot and Aboot
Which this is.
dave3825
Suffolk County NY
i am going to try to write to full database if that dose anything ????
If it were me, I would start fresh. Import the system with all sites to a fav list and set the sites your not interested in to avoid.
You don't give many details and force write full database is not going to do anything for your favorites lists. All the does if update the full database in the scanner.
Torontoteamone
Spoonfed
Are you saying i created a favorite List with all sites and Service type I need like start over ?
dave3825
Suffolk County NY
I am saying if I added sites to a system, and did not know why it’s not adding, I would create another fav and append the whole system to that and see if it works. Then avoid what’s unwanted.
You don’t give many details about anything that you have done.
Did you purchase and install the NXDN key in the scanner?
Torontoteamone
Spoonfed
So when I upload NXDN on q I do a favorite list I put on filter invert I create a favorite list for TG but when I scan it it doesn’t seem to work play any Transmission I select service type I want but my other NXDN system work 96 is pefect but not 48
Torontoteamone
Spoonfed
Can you export the fav list and post it here?
I’m not on my computer right now the favorites list is
NXDN 4800
Site
Hill​
Site Number:Decimal: 023 / Hex: 17
Description: Dwyer Hill
Unique DB ID:30456
RAN:23
County Location: Ottawa
Neighbors: N/A
Modulation: N/A
Notes:N/A
FCC Callsigns:N/A
Updated:2017-09-03
Site Frequency Table​
CH IDFrequency
126462.3375c
127460.0625c
Site Location Data​
Latitude:45.1272Longitude:-75.9457Range:30Type:Defined Coverage
I only put in 1 site
dave3825
Suffolk County NY
That is not a favorite list. That’s a data base listing for a system.
Favorite list will show your programming which may help people identify the problem you are having.
Torontoteamone
Spoonfed
I will see what I can do when I go back on my computer it seem to be only one NXDN system so far not the 9600 only 4800
gary123
Ill send him a seninel OnQ favorites. I kind of owe him for messing up the thread earlier :).
