NXR-810 Autodial
joehoose2700
Milwaukee, WI
Hello,
Can the PF keys on the front of the NXR-810 be programmed for DTMF Autodial? I tried to look in the programming software a long while ago and I can't remember seeing it at first glance.
Preferably, I'd love to have ONE specific DTMF code assigned to each different PF key, but even if I can access the list and press/select up/down that would be cool too
ramal121
Lots and lots of watts
Calif Whine Country
The only time the NXR will encode DTMF is the transpond response to either remote control of the PF keys or activation of the aux I/Os.
joehoose2700
Milwaukee, WI
short cut way, get a KMC-66 dtmf mic, manual dial.
I actually tried this and wasn't able to transmit to other radios, even just voice. Maybe I had a bad mic, but just plugging in the mic and attempting to talk, I wasn't able to transmit. Are there any settings required to permit that in repeater mode?
kd4efm
EL98 Florida
USUALLY, when you do that, your just local PTT, check your ptt priority in the settings.
(dont have 129 on this pc to show you)
ramal121
Calif Whine Country
Does a NXR even decode the keypad serial data from the mic and know what to do with it? I don't know the answer. You may have to fall back to an older mic with a DTMF audio encoder hooked to the mic hi line, like a KMC-32.
Looking at the indepth manual, there is a way to use one of the external inputs on the DB-25 to trigger sending a DTMF string.
They do not show a DTFM mic option, however.
You could set up an external trigger, or just add an external DTMF sender.
joehoose2700
Milwaukee, WI
I think en external sender may be the way I'd have to go, but I have no clue where to start looking for something like that.
I know it's off-topic but if anyone has ideas, I'd love to talk! :)
