NXR-810 Simplex Question
chrishoerner
KC3KSJ
Frederica, Delaware
Would it be possible to put an 810 in RF Link mode but use the same frequency for tx and rx. Would I just run 2 antennas? I read that in simplex mode the repeater will just use the tx antenna port for both. It does not mention that being the case in any other mode. The goal is to hear wide area communications from ip network by talkgroup, But if the repeater goes away it doesnt matter to the end user.
kd4efm
Florida
Base mode or simplex, uses an antenna switch.
I will have to dig up the notes for it, but it's a little bit more detailed on doing what you're looking to do.
