Wireless bridge not linking repeaters
Calrad
Unfortunately I only have this screenshot when I upped the Tx power. Next time I am up there I will set the spacing to 10MHz again and keep the Tx power at 25dBm. Will have an EIRP of 55dBm so things should work better then. Will remove the gateway and DNS as well and post an update then. Thank you everyone for your inputs. It is much appreciated
Calrad
So an update. I went back up there and changed the spacing to 10MHz and put the tx power as high as I could. I also removed the DNS stuff. It seems to have paid off as the link connected and works perfectly as they need. I know the power is overkill but the fresnal zone isnt great. If they were higher up on the tower I could have got away with lower power. Not the best possible solution but it works and the client is happy.
Cameron314
I would not say your power is too high. You are still right on the edge of what is a usable link.
Calrad
This is true. Has been a valuable learning experience and going forward I have a better idea of what is required and how to go about it. Will definitely look into other radios for the wireless links should clients want one at such a distance. Luckily all that is needed is voice to go through this link.
