- Joined
- Dec 1, 2006
- Messages
- 620
I use Proscan and the RR data base to program my BCD325P2 and for the most part ever system I put in works well. But the Ocean County 700 P25 TRS just doesn't work. I'm in Toms River so I should have no problem receiving they system. With the stock program loaded I don't even show a control channel signal. I started playing around with settings and I changed the format setting from Decimal to HEX and the CC signal showed but I didn't pick up anything. I changed my ID scan/search from scan to search and I pick up TG's but it stopped for a few seconds made a noise and it started scanning. I noticed that the TG's on the search was different from the ones in radio. I changed them all to the matching HEX TG numbers and I still get the CC signal but it's not stopping on any TG's. Is there much action on this system? Do they simulcast the OC UHF system on it? If they do, I'm getting the UHS TRS on another radio but nothing over the 325. As I was typing this out it answered my question, they do simulcast, but the P25 TRS barely came in and the UHS TRS on the other radio was loud, clear and had the full messages and both sides of the conversation. (I'm back in ID search, it doe's ID the tag info I put in) Just trying to figure this out. Thanks
