jazzboypro
After checking for water and connection at the transformer and redoing the connection and made sure it's tight i juste lest the transformer on the chimney with the antenna in the air but really sagging and made measurements. SWR was acceptable on all bands. After raising the transformer to it's final position i'm back to square one with high SWR on every band. That got me thinking, the transformer has a hook on top as if it was made to be suspended. In my case what i did is i made an aluminum bracket and used 2 screws to secure the transformer to the bracket and then i attached the bracket to the mast with a U bolt. Can the bracket have an adverse effect on the antenna ?
