OCF swr issue
prcguy
Well, i spent most of my weekend trying to make this antenna work but to no avail. The fiberglass mast does not make any difference when compared to the mast that was there before. I tried to put the transformer on the mast itself and away from the mast but it does not make a significant difference. I try to put the mast a different heights and again no significant difference. Tried to attached the coax to the mast and also to let it hang from the transformer and again, no significant difference. At this point it would require an external tuner on a at least 5 bands. I suspect not much power would get at the antenna. Other than trying to lay the longer leg of the antenna differently i'm out of idea.
I think its time to run some tests as mentioned in post #2, or put the wire from your 40m version on the 80m transformer and it should match up identical to your 40m version. If it doesn't then something has gone wrong with the transformer.
