I recently noticed an odd issue with the RSSI indicator on my SDS100. Sometimes this indicator doesn't display at all (i.e. zero to one bar), sometimes it displays as one should expect it too as transmissions are received. After careful observation, it seems that the temperature of the unit is a factor. When the unit is below room temperature, the RSSI displays normally. Once the unit warms up, it no longer displays or only indicates one bar.
Adding to the mystery is that I don't seem to be missing any transmissions. Additionally, the transmissions received don't seem to be any more garbled (digital systems) or contain any more static (analog systems) than normal. To verify this, I placed it side by side with my BCD436, using the same model antenna, and scanning the exact same system, sites, and talkgroups. The SDS locked onto the same sites and talkgroups the BCD did, at nearly the same exact times, and the audio from both was of the same quality.
I recently updated the firmware on the SDS, but I can't recall if this issue appeared before or after that update.
