This is the second copy of the radio. The first one has poor sensitivity especially noted on VHF-UHF. Second copy works much better. Performance on the Centre County, PA system, the Washington County, MD system and the Dauphin and York County, PA systems is more than decent. It seemed to work well on a short visit to the Phase II PG County, MD system (with the North and South programmed as separate favorites) The only major problem that I've noticed is the fact that the radio does not stop on certain talkgroups although when manually dialed into those groups reception is just fine.
Question: Is there a location to learn manual programming on the "fly.?" Also, how to program an "open" bank, essentially to monitor all traffic on a system? Thanks!
For programming steps, probably your best first step is on the Easier to Read Manuals
site. Look at the link for 436HP/536HP
Sentinel version. Other than the added options for display on the SDS100, and the NAC field entry for trunked systems, programming is pretty much the same for all of these scanners. If you are missing certain talkgroups, are the service types enabled? And, if using location control, are the MIA TGIDs in their own manually created department? or in a department with other IDs that are normally received without issue?
There is no "open bank" option on the DMA scanners. Open bank was what was used on the older Radio Shack scanners, such as the Pro-97 or Pro-96/-2096. For the Uniden scanners, if you want to hear all active talkgroups on the system, then set the system to "ID Search" instead of "ID Scan".
ID Search will stop on any active talkgroup it finds, except for TGIDs that have been locked out (avoided) or that are in a Department that has been set to Avoid. If the ID is programmed, then you'd see the TGID as well as the text tag programmed. If active (and not locked out as noted), but not programmed, then you'd see only the TGID when the scanner stops on it. If the ID was programmed, but it's Service Type was not enabled, it would also be skipped, regardless of whether ofr not set to 'Avoid'.
ID Scan will scan only the TGIDs that are programmed in the system on the scanner, that are not avoided, and are not in a Department that has been avoided. As above, the Service Type would need to be enabled, regardless of Avoid status.
