ohio marcs scanner question
colliers_628
Weirton, WV
which scanners on the market are capable of monitoring the ohio marcs system. and which would be the best to invest in?
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
All of the following scanners will:
Digital Scanner Comparison Chart - The RadioReference Wiki
In addition, I believe some older generation Unidens with the digital cards are also currently able to monitor MARCS such as the BC796D and BC296D.
You should get a scanner that supports rebanded systems, since MARCS will eventually be rebanded.
I'd certainly recommend the newest generation scanner you can buy (RS PRO-197 / PRO-106, Uniden BCD996[X]T / BCD396[X]T, or GRE PSR-500 / PSR-600.
Mike
