I worked radio comms for the oil and gas industry for ten years, and it was dominated by Motorola: analog conventional, P25 ASTRO and DMR toward the end. However, initially it was sometimes dual band Vertex Duo and Yaesu FTH-2070 VHF/UHF IS rated radios. Dual band in one radio was great, but the industry was still very much Motorola, with some people carrying multiple radios to cover VHF, UHF, and sometimes 800 MHz. Vehicles and fixed locations often had one of each, mobile radios, along with horse trailers and commercial construction trailers being equipped as mobile comm suites. I even had to maintain Motorola Centracom dispatch gear, later Gai-tronics and Telex/Bosch communications dispatch consoles on board oil industry related vessels and fixed sites.
British Petroleum was pushing for Trbo XPR6550 handhelds as of 2010, with many others following by the 2013 12.5kHz narrow-banding mandate. XPR6580 and XPR7580/e have become more popular, as 800 MHz works better in the production environment, higher frequency gets around the metal piping and machinery better than UHF XPR6550/7550/e radios.
Some support entities tried going Hytera to their demise with the Motorola lawsuits. The attempt was to save money and have more handheld radios for use on anti-pollution ships, that respond to oil spills. Another issues was the need to support DMR, and have an appropriate interface with dispatch consoles. Telex had their Trbi adapter for MotoTrbo, and Telex wanted users to migrate from IP-223 IP interface devices to IP-224 interface devices, which meant a lot of money to upgrade. An issue in the oil and gas industry was the divergence between those that went or stayed P25 and those that went DMR, sometimes within the same company but different regions of the country.
Now, I work in another industry where there is still a need to interface Motorola radios in an industrial environment, and sites across the United States. However, Zetron IP interface gear allows for ASTRO and Trbo to be combined, with radios in analog mode to pass MDC ID's correctly. Motorola still appears to dominate when production environments, machinery, and the need to keep reverse compatibility with legacy Motorola gear is needed.
