OK, what am I missing here?
AZScanner
Somewhere in this room. Right now, you're very col
I tried to build and install DSD 1.4 on Ubuntu 13.10, but when I attempt to run it, I get this error:
dsd: error while loading shared libraries: libmbe.so.1: cannot open shared object file: No such file or directory
The library file is in usr/local/bin where it's supposed to be, so I'm stumped. Is it looking for it somewhere else?
Thanks for any help.
-- Nevermind, figured it out. The libmbe files just need to be copied to usr/lib. For some reason the build process put them in usr/local/lib instead. Weird. Now I just need to figure out how to get it to see the correct audio device but I know that's here on the forums somewhere. :)
-AZ
AZScanner
OK, got past all that after doing much reading up on this forum and elsewhere that Ubuntu 13.10 doesn't have a dev/audio for DSD to use. Oh brother...
I managed to get DSD to run by using aoss to emulate the old dev/audio it wanted to see:
aoss dsd -f1 -mg
and it chugs along happily after that, BUT it's just not decoding diddly squat. Lots of "ignoring ldu2 not preceeded by ldu1" and all that nonsense. Every now and then a little audio blurp comes out with lots of errorbars but other than that, silence. I think the fact I'm running it thru aoss is to blame. Has anyone gotten this to run on Ubuntu 13 successfully? If so, I could use some help - please share how you got it to work.
Thanks,
-AZ
