foster_006 said:
Really, it depends on what you listen to the most. I pretty much listen to everything around..
Oops, I meant to say 800, everything else is fine.
Will have to check out the 800 Duckie on the way home.
I just now only found mention of 1 mod for the RS mag mount, but it was for 2m range, to cut a .75 to 1" chunk out of the middle of the antenna. Will take a stab in the dark it's to cut a bit from the top section of the antenna.
And I'll guess I should be able to hear the "outside" part of OCPD's new TRS in Edmond and on north? Have some new & updated freqs now from here and will be comparing and reprogramming some soonly.
Also: have a 785XLT, not reinstalled yet, and pro-92, mostly for backup and the wife's vehicle, and pro-2006 sitting here above the computer.
