Once again problem with audio3
miccona
Tampa, FL
My feed is down again............but yet my feed on audio9 is fine as it always is i really wish my feed could get moved over to audio9 this is an everyday occurrence with audio3 server perhaps an ADMIN could share light to why EVERYONE is having issues
Deziel0495
PEI/NB Database Guy
PEI
Looking at my RadioFeed status log it shows it is loosing connection with the server quite often as well. Quickly connects again with no issues.
miccona
Tampa, FL
over an hour later feed is still down unable to connect to audioserver3 waiting for a resolution
GordonE
Scanner Radio App Developer
Thanks for submitting the help request/support ticket, I moved your feed over to audio9.
johnmac
Westminster, Ma
I am also having a constant problem with my 3 feeds for the past 2 days. Connection does not last for very long. I believe I am using audio 1 & 3.
Also, my home page does not open with my preferences.
miccona
Tampa, FL
well since being switched to server 9 ive had not one issue
GordonE
The problem is most likely somewhere between your computer and your ISP based on the fact that you're having problems with all three of your feeds, 2 of which are on audio1 and 1 on audio3. The feed I provide is relayed by audio1 and has had no connectivity issues.
miccona
Tampa, FL
Gordon maybe my good luck is just a coincidence but my feed on server 9 has always been strong and now my 2nd feed is going strong with no timeouts so far.
jasonhouk
Uniden AlphaMan
Uniden Representative
Marion, Ohio
Same issue here with my feed. Happens daily and is getting frustrating.
Blind_Shadow
My feed went down again today. This is the 2nd time in 48 hours. Audio 3 server problems do not seem to be fixed yet.
GordonE
I've moved my own feed to audio3, I'll monitor it to see if I see disconnects.
blantonl
Founder and CEO
Dallas, TX
We had an outage on audio3 on 2/6 at 9:00 PM CST, and this morning we rebooted all the audio servers to implement some maintenance.
Other than that - we haven't had any other problems or outages on audio3.
Additionally, I have over 5 feeds hosted on audio3 that are broadcasting from 2 separate locations, and I've not experienced a single problem with disconnects or connection problems.
There are a lot of factors in play for real-time audio streaming, and almost 90% of the time the issue is with the "last mile" connectivity.
N4RMT
But, if the app you're using says "unable to connect to audio server"...
My feed has been returning that message to two separate apps all day today. It is on audio3.
Randy
GordonE
When people connect to your feed they're not connected to audio3, they're connected to relay.broadcastify.com and then forwarded to a random server that we used to relay audio to listeners (audio1, 3, and 9 are used only to receive audio).
Also, my feed has been stable after I moved it to audio3 (except for a power outage at my house).
N4RMT
But if my scancast is running, and not reorting errors, and the message from the app is cannot connect to audio server, wouldnt the problem be on the server side? it doesn't say this feed is down, it says it cant connect to the audio server. Just trying to understand and get my feed back working.
GordonE
When you get the error from the app, check to see if you can listen to the feed via the Broadcastify.com web site using your computer.
webstar22
RenfrewCountyScanner.com
Ontario, Canada
GordonE I've been getting the same from Scanner Radio for the past two days.
Works on Wifi, not normal data.
webstar22
Ontario, Canada
Also I am on audio3. I don't see the disconnects everyone else talks about and I monitor my feed stats using PRTG on my home server so I would see the drop in listeners if there was a disconnect.
N4RMT
I checked and in fact it did work on Broadcastify. Not sure then, but thanks.
Randy
