OneVoice Network 171 (CT, MA, NH, NJ, NY, PA, VT)
DaveNF2G
Latham, NY
(It's tough to update a submission after it's closed out.)
I submitted a CC change for Site 25 which was rejected. I went back and checked my event log and discovered that DSDPlus lost the control channel at some point, went looking, and found a different site, which had a different CC. The system was busy, so I didn't notice the change in site.
sh7411usa
FYI "AB" Hex = 171 Dec. TRBO/DMR systems are commonly referenced by their Dec ID, not Hex like we do for P25 systems.
Anyway, look in the Lakewood area for Site 36...Color Code 11 for all repeaters.
LCNMHz
07454.19375c
08454.21875
09454.24375
10454.25625
11454.31875
12454.33125c
13454.56875
14454.58125c
15451.009375c
Does anyone know if this information is still current? I'm attempting to confirm this site, as it is still not listed in the DB. Confirmed LCN 7 and 14 using LCN Finder, haven't received traffic on any of the other channels yet.
Additionally, can anyone help with SDRTrunk setup?
I programmed the info, assuming that LCN 07 corresponds to LSN 13 and 14, LCN 08 to 15 and 16, etc. Though given my limited knowledge, am not sure if this is correct.
Getting a weird issue though - SDRTrunk (using one RTL-SDR) is not properly assigning the channels, although I'm convinced I set it up right.
Take a look at this screenshot:
As you can see, SDRTrunk decodes a data call on LSN 14, you can see both the control and traffic active in the waterfall. However, although LSN 14 is properly assigned in the map (at least AFAIK), for some reason it says CHECK LSN CHANNEL MAP in the details, and it did not trunk track.
Any help would be greatly appreciated!
Thanks in advance.
seagravebuff60
Short Bus Reject
this came in from the area of Route 9 and 70 in Toms River by the Lakewood border,I'll run the LCN finder another time.
Perhaps you are picking up the other NJ system with the same System ID? I don't see any 47x frequencies licensed at or around West Orange. Did you pick up any voice activity?
GTR8000
NY/NJ Database Guy
BEE00
Reminder that this thread is about the Con+ system. Posts about the new Goosetown Tier 3 system should be made here:
DaveNF2G
Latham, NY
Site 77 has an LCN 4 (submitted to DB) and is advertising neighbor site 85 (location unknown yet).
DaveNF2G
Latham, NY
Further monitoring from my location in eastern NY has shown a different channel configuration for Site 77 than is listed in the DB. I have not submitted this data because the signal is not really strong here and I think my findings should be checked by someone with better reception.
This is what I have now:
454.6000 LCN 1 - not heard or listed by controller. My FMP24/DSD+ setup cannot distinguish this from 454.59375, which is Site 80.
463.2125 LCN 2 CC1 - works as listed
452.5500 LCN 4 CC1 - new channel (already added to DB)
463.4125 LCN 5 CC2 - current control channel - different LCN position and color code from DB
dave3825
Suffolk County NY
Site 32:
West Orange / Eagle Rock (Confirmed)
Neighbor Sites: 33, 36, 37, 38
454.3250 Color Code 12
502.1000 Color Code 1
502.3000. Color Code 1
Up in North Jersey - Site 32 (502.1000 and 502.3000) at Eagle Rock seems to have gone offline
Can anyone out that way confirm if this site is on the air and if so, what freqs, LCN and LSN are in use? Specifically 454.3250 LCN and LSN info.
seagravebuff60
Short Bus Reject
One of the repeaters/LCNs went TIII in September. (I think). Maybe other repeaters will follow.
seagravebuff60
Short Bus Reject
I went through the Garden State Parkway Corridor, looking for any NJ Sites still on the air in that area (29, 31, 34, 37, 62). I could only receive Site 29 (the 454 one). Everything in the DB for that site is correct. Except I noticed no CC was designated in the DB; it was 454.55 when I listened.
I was only driving through, so the monitoring conditions were not ideal. Can anyone closer to the sites confirm if the sites are still online or have moved elsewhere?
Whiskey3JMC
Google-Foo Ninja 4 Hire
Simulcastylvania, TE
Now seeing a new 171 Site 30 online from Waterford Works on 501.8125, CC1, WRBM433
The RRDB listed 171-30 is still online @ 471.9625, CC2. No traffic observed from this site all day (albeit it is Saturday)
So I'm guessing the 501 site will eventually replace the 471 site with the cancelled license. I'm only in the area until tomorrow morning while I dogsit for my bro & sis in law. Will keep the SDR parked on the new site overnight but doubtful I'll log anything notable
So I've confirmed Waterford Works (Site 30) is no longer online on 471.9625 (I previously had pick up on it from PA). Can anyone closer to the area plug in 501.8125 and see if anything's changed from my observation last year?
Whiskey3JMC
Back in South Jersey for the week, 501.9625 is now active CC on Site 30. Being it's Sunday I don't expect to log much if any activity here. Will check back tomorrow to see if activity begins...
Whiskey3JMC
This site's a ghost town, nothing but a small handful of affiliations. CC now back to 501.8125
