Onslow County
w4rez
Parkersburg
Does anybody have lists of the various 10 and dispatch codes in use in Onslow County?
It sounds like the 10-code that Jacksonville PD uses is a combination of APCO and Charlotte PD. They also use "signal" codes that I am not familiar with.
To confuse things further, Onslow County SD sounds like they use 4 digit codes for different types of calls, and Onslow County EMS uses 4 and maybe 5 digit alphanumeric codes for different types of calls.
Do any of you guys have these?
w4rez
Parkersburg
Also...I just observed a talkgroup in use on the Jacksonville/Onslow trunked system that's not listed here: 52368. Started blaring telemetry nonstop about 1AM and is probably still blaring it.
KE4ZNR
Radio Guru
Please submit it to the RR.com database...that way we can keep the info updated!
Thanks!
Marshall KE4ZNR
Robbyboy
Cat Herder
Western Wisconsin
What kind of scanner are you using? In 2 years (to include today) I have never noted any telemetry talkgroups on the Onslow County system. Not saying it does not exist, just have a hunch on that TGID....
Cheers
w4rez
Parkersburg
Cheers
Radio Shack Pro-2052 analog. It could very well have been a digital transmission since I'm not familiar with how the sound nor what the bitrate of digital is. It sounded much like some sort of 4800 baud telemetry to my (half deaf) ears, however.
BryanTheRed
NC
Having worked EMS & Rescue there for 4 years let me see if I can help you. The 10 codes are standard 10 codes! JPD who knows, I never could get those down they have some wierd signal codes. OCSD uses the 4 digit NCIC codes, good luck finding those, I think I have a copy somewhere. OCEMS uses EMD codes you can find those online, just remember they updated to the newer EMD codes about 6 months ago! Hope this helps.
