OP25 and Los Angeles
awooga
im tryimg to follow LAPD trunked systems but cant seem to find the TGIDs and Alpha tags to do so.
im very new to OP25 but understand to follow trumked communications the TGID and Alpha tag is all i need
i can see all the LAPD frequemcies but hardly any TGIDs
can anyone familiar with usimg OP25 in LA help explain what i need and where the info is so I can generate a .tsv file to follow the different talkgroups (i assume there are many?)
Broadband (user) showed me how he set his tsv file for Las Vegas but the same info seems harder to find for LA
thanks!
awooga
marcotor
I ♥ÆS Ø
Sunny SoCal
LAPD isn't trunked. It's P25, conventional :)
There is a small P2 trunked system on Mt. Lukens, but I do not think is currently being used, outside of some testing.
awooga
so how do i monitor more than one frequency in op25? control channels? where do i input that?
kma371
As previously mentioned, they are not trunked. You do not need any control channels because there aren't any. Program them as conventional.
awooga
trying with --args just for frequeny im getting thus error
./scope.py --args 'hackrf' -g 65 -f 484.93750
osmosdr source_c creation failure
Traceback (most recent call last):
File "./scope.py", line 2751, in <module>
app = stdgui2.stdapp(p25_rx_block, "APCO P25 Receiver", 3)
File "/usr/lib/python2.7/dist-packages/gnuradio/wxgui/stdgui2.py", line 47, in __init__
wx.App.__init__ (self, redirect=False)
File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py", line 7981, in __init__
self._BootstrapApp()
File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py", line 7555, in _BootstrapApp
return _core_.PyApp__BootstrapApp(*args, **kwargs)
File "/usr/lib/python2.7/dist-packages/gnuradio/wxgui/stdgui2.py", line 51, in OnInit
self._max_noutput_items)
File "/usr/lib/python2.7/dist-packages/gnuradio/wxgui/stdgui2.py", line 73, in __init__
self.panel = stdpanel (self, self, top_block_maker, max_nouts)
File "/usr/lib/python2.7/dist-packages/gnuradio/wxgui/stdgui2.py", line 96, in __init__
self.top_block = top_block_maker (frame, self, vbox, sys.argv)
File "./scope.py", line 156, in __init__
gain_names = self.src.get_gain_names()
AttributeError: 'NoneType' object has no attribute 'get_gain_names'
kma371
I don't know what any of that means.
Since your asked your question in another forum anyways, please continue your discussion there.
