OP25 audio
KF4HJW
Newport News , VA
So i have OP25 running and have audio when I do manual start of the software.
I finally got to create Audostart of the software and that works starts OP25 right up fine.
However no I get no audio. I can stop the software and go back to teh op25.sh file and tell
it to execute and I get audio. I stop the software restart the software and no audio, reboot no audio.
Any ideas on where i can look for my mistake.
boatbod
Talbot Co, MD
Most likely it'll be PulseAudio permissions.
When op25 is started at boot, it generally has no access to PulseAudio because that doesn't start until a user logs in to the desktop. There are things that can be done to address this; you might reach out to @wgbecks for further guidance, but first he's going to need to know what hardware & os release you're running on.
KF4HJW
Newport News , VA
Thank you your thoughts pointed me into the right place for my pi4's. No will located instruction for my pi3b.
Again thanks
wgbecks
NE Wisconsin
However no I get no audio. I d no audio, reboot no audio.
This is indeed an issue with the PulseAudio permissions that enforces user authority as opposed allowing operation as a system wide daemon as @boatbod mentioned. Let me know what OS you're on and I "might" be able to help out with a workaround that permits PA applications to run as system services. IE: Headless operation.
I've had to deal with this vary problem in that all of my instances of op25 run in a headless configuration and whereby I make use
of Liquidsoap to process my local and streaming audio sources.
Please note that I am going to be in and out over the next several days and may not be in a positon to offer a timely response.
Bill
