OP25 OP25 DES-OFB help and advice
luciano_frc
Hello, dear radio listeners
I have a RTL-SDR Blog V4 dongle, which I bought about a year ago.
In my region, I have many DES-OFB op25 transmissions and very few unencrypted transmissions.
I have tried a few things to be able to listen to the transmissions, but I have not been successful in this task.
I believe that I am not able to get the settings right and that is why I have not been successful.
I used the boatbod op25 but I was unsuccessful.
I would greatly appreciate any help and guidance, and I would like to thank everyone in advance for their time and patience.
I have been using this syntax in the op25 Boatbod version
Code:
/rx.py --crypt-behavior -1 -k example_keys.json --args 'rtl' --gains 'LNA:49' -S 2000000 -o 2500 -U -f 171.50625e6 -2 -l http:0.0.0.0:8080 2> stderr.2 -X
I will attach an IQ recording and the DSD-Plus Fastlane log
https://get-storage.b-cdn.net/IQ-Record-And-FM.zip
some screenshots
  • 1R-log.txt
boatbod
Talbot Co, MD
Do you know the DES keys and are they populated in the keys file? If not, you will not be listening to any of the encrypted transmissions.
N4KVL
ÆS 8675309
South FL
Have you tried hacking The Gibson yet?
RayAir
Hi boatbod, thank you very much for the quick response!!!
I am using the example_keys.json
but I don't know what the key is, is there any way I can get the keys ? maybe via DSD-Plus Fastlane, or some other way ?
Start at 0101010101010101 and work your way up to FEFEFEFEFEFEFEFE. It will help if you type really fast.
MUTNAV
I realize the humer of your post.... BUT, (actual honest question) why choose those start and end numbers.
lwvmobile
DSD-FME
Lafayette County, FL
Alright, I'll take a crack at answering this, but DES is expressed as a 64-bit key, but only 56-bits of that key are actually useful for encryption. For every octet, or byte, of key, there are 7 bits of key, and 1 bit of parity.
Using the example 0x0101010101010101, and just looking at one octet since it repeats, this is easy, but essentially
Hex: 0x01
Binary: 00000001
When expressed as binary, only the first 7 bits are valid key for this octet, and the last bit (the 1) is the parity bit. Since there are 7 (odd) number of zeroes, then the parity bit is 1. If the number of zeroes where even, then the parity bit would be 0 instead.
Hex: 0xFE
Binary: 11111110
In 0xFE, there is seven 1s, and zero 0s, so its parity bit is 0.
So in essence, start counting at 0x0101010101010101 and making sure all parity is correct, although, depending on the implementation, the parity bit may be entirely ignored, allowing incorrect parity keys that will also function exactly like their parity corrected counterpart. Or if the parity is checked by the implementation, then it may reject the key. In practice, the key value of 0x0000000000000000 is exactly the same as 0x0101010101010101 in DES.
MUTNAV
Hex: 0x01
Binary: 00000001
Hex: 0xFE
Binary: 11111110
Thanks, still assimilating the information.
hrh17
Chuck up a dsdplus raw recording from the voice channels
