Option Board??
ozzie
mn.
Does vertex make a rx only add on board for the vx4200 or the vx4600 radios. If so where is the best place to obtain this part.
k7plt
Not sure what you are asking, are you referring to have the radio only recieve on certain channel(s)? or adding an addon board to perform certain function globally on the radio? Please specify . . . thxs
radiotweester
Oregon
Yes, for the VX-4100/4200
SRX-1 adds UHF to a VHF radio and SRX-2 adds VHF to a UHF radio.
They use to be about $100 and you can use the VDME-200 or other option boards with the SRX installed.
I can't recommend a dealer as I'm in Oregon and I think they're still bound by territorial restrictions.
Side note - If you have an older VX-4100/4200, there was a problem where the casting of the "lid" would make contact with the SRX board. Sent it to Vertex and all they did was grind down the offending piece.
