Orange County system issues
TonyOrlando
Orlando, FL
call me crazy, but has anyone looked at the signal strength of the prime site CC?
i can normally copy this 85+% from my QTH.. as of today, I can't decode squat. perhaps the CC transmitter power is down?
just a thought.
FWIW
With the control channel programmed in the G4 as a conventional frequency, I'm getting 4 bars of signal strength @ RSSI between -86 to -95. I am hearing traffic normally on my BCD436 (albeit with a bit of some the usual simulcast distortion).
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
Are you guys sure the site isn’t in site trunking? I believe the G-series has a setting for that which needs to be checked. Just a thought.
TonyOrlando
Orlando, FL
Tried that. Actually I usually keep that enabled on all systems I monitor. I can't imagine that the county wouldn't have caught and fixed that after 5 days... ish.
KevinC
32D2T/957.282
Super Moderator
Do you have a link you can provide to this thread on the Unication forum please? I was unable to find t.
Thank you.
jgorman21
Glenmont N.Y.
Thank you!
ThreatLevelMidnight
Georgia
FWIW, my SDRtrunk site in the NW area of orange county is decoding just fine, and has been this whole time, more fuel to the unication only problem
WX4JCW
Stow, Ohio
Funny that they have been working just fine for a while then multiple pagers from different people go down at the same time, now I heard the Orlando site works fine
jcardani
Orlando, FL
I got a chance today to run an older version of OP25 on both the main simulcast site 1.1 and Disney site 2.1 and compare the traffic information received by OP25. While site 2.1 information populates perfectly, site 1.1 does not but TSBKs are being received with no errors. Also OP25 works with encrypted audio on 2.1 but noting is received on 1.1. So it appears the band plan and other critical info is not coming over the control channel for site 1.1 only. See pics of OP25 for both sites below.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
And since Unication devices rely on the bandplan being received over the control channel, it's not going to work.
jcardani
Orlando, FL
So is this something that can be shut off or did something break in the controller?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
P25 systems don't need to send out bandplans but 99% do. Most subscriber radios already have the bandplan programmed in so there's really no need for it to be sent out over the air.
I assume scanner owners are manually programming in the bandplan to get around the issue. Will have to wait and see what Unication comes up with.
Darkspace109
Is there a way to add it to a unication. Also why would the other sites still be sending it and not the main one?
