Orangetown PD
nyscan
Has OPD made a decision not to join the Rockland County trunked public safety system? I know they found some problems during testing. Since it's been over two years since the system went live you would think there would either be a resolution to the problems or a decision that they can't be solved.
N2ACF
Rockland County, NY
No, they have not made a decision NOT to join the system. In fact, they're quite anxious! However, due to a small area of "in building" coverage concerns in downtown Nyack, they have requested the radio committee see if "anything can be done" to solve the issue and bring coverage to the affected buildings.
The system design called for 97 percent on street coverage and the sites chosen brought pretty good coverage in buildings as well. However, Nyack has some really dense 24 to 30 db buildings which are tough to penetrate and get even worse in the basements!
OPD has found several areas of their jurisdiction in which the new system exceeds their existing system. Unfortunately, 30 percent of their call volume (stats provided by them) is generated in the downtown Nyack area where their existing system works better. This is due to an analog simulcast transmitter & receiver they had strategically installed in this dense, downtown area. The closest Trunked Sub-site is 1.2 miles away.
In the weeks to come, the committee will be experimenting with potential solutions and should one prove effective, monies will have to be found to support it. The budget for the trunked system is basically exhausted now that the system is complete.
So again, to answer your original question, no...they have not made any permanent decisions at this time.
Hope that helps!
nyscan
Looks like OPD is live on the RCPSCS. No VHF simulcast heard.
GTR8000
NY/NJ Database Guy
BEE00
Orangetown PD (and by extension Piermont and South Nyack) cut over to the 700 MHz system at 0800 hrs on March 2nd. There is no VHF simulcast.
GTR8000
NY/NJ Database Guy
BEE00
No additional subsites have been added. Coverage in downtown Nyack will be enhanced once the installation of a DAS (Distributed Antenna System) is complete. The police departments made the decision to go ahead and cut over ahead of the completion of the DAS installation.
Ishmole
Walden, NY
Were there any changes done to the original programming? I and along with another friends radio that I programmed with the data from here are not receiving anything, It is programmed as TGID 2031. Am I missing something?
Mike
GTR8000
NY/NJ Database Guy
BEE00
The database is accurate. Talkgroup 2031 is correct, and is "in the clear" (no encryption in use).
If you are able to hear other talkgroups on the system, you ought to be hearing the Orangetown talkgroup just as well.
GTR8000
NY/NJ Database Guy
BEE00
Excellent, happy monitoring!
