Osceola P25 (48E.BEE00)
batdude
Florida Db Admin / Florida Forum Moderator
Moderator
East Central, Florida
I've been monitoring this system from my QTH for the last couple weeks. Reception here in Brevard isn't that bad at all. Is anyone here actively monitoring this system?
some of the outlier talkgroups I have not figured out yet:
003 --- does a radio check every morning around 0800
030 --- unknown. Usually only use first names, Steve, Joe, etc.
057 --- seems to be mostly people going on and off "the clock", checking in, etc. (?)
069 --- community center (?)
085 --- Surveillance channel (in the clear) - suspected to be OCSO
091 --- seems to be some kind of back channel to the Osceola Regional ER - this TG is way out of sequence of the other "hospital" talkgroups
141 --- LOTS of Spanish speakers on this TG (unknown)
183 --- seems to be a "LE NET" - and unencrypted. Used to coordinate across agencies it seems.
243 --- out of sequence OCSO Jail TG (?) - other TGs that seem to be jail related are 149. 151. 153, 161 (OI have 31000+ PTTs on TG 161, 7000+ on 153)
207 --- seems to be Kissimmee PD Channel 2 - but ENC, so ?
TGs 257, 273, 275, 280, 285, 287, 293 332 all seem to be "Utility" related... water, power, sewer, actual channel names = no idea
307 and 309 seem to be St. Could PD Channels 2 and 3 --- unknown though due to encryption
Open to thoughts, comments, ideas...
doug
Bote
know-it-all
Ft. Lauderdale, FL, U.S.A.
If you're feeling ambitious you could set up UniTrunker v2 with a couple $20 SDR dongles and watch which radios affiliate with which talkgroups. That metadata can be quite revealing. You can even confirm the encrypted channels if those units ever switch over to a clear talkgroup, but you'd have to be listening at the time to know.
batdude
Moderator
i am running two AirSpy SDRs with FMPA+DSD+ :)
batdude
Moderator
TG169 is active this morning with what sounds like vehicle surveillance; suspect LE due to use of 10 codes, running license plates, etc. No idea which agency.
batdude
Moderator
Here are my latest updates on Osceola ... the TG PDF are all of the "unknown" TGs that I have collected over the last couple days (13-14 August).
The RID dump is a complete dump from DSD+ of RIDs seen on the system, sorted by TG.
  • TG.pdf
  • Osceola RID dump.pdf
Scott_93
Firstly - I'm not at all even in the area. However, since you posted the data, I thought it would be an interesting exercise to put it through Excel and make some assumptions. I have included it as an attachment so you can use it. Sorry if people have already done this, hopefully, I'm not coming across as patronising.
TG169 has been affiliated by radios (59182**/59182** range) that have also affiliated with TG47, which is in the block of TG's (42,44,46,47,48) that look like OCSO groups, so I'd say an OCSO group, possibly specialist units. Would be worth keeping an eye on any TG's those RID's affiliate to.
TG85 in as OCSO Surv has some interesting RID's affiliated, those in the 900**** and 500**** range which don't seem to affiliated to much else, I'd keep an eye on what and where these RID's go and how many unique RID's affiliate to the groups over time, not sure it's an OCSO group though.
TG309 seems to have RID's from St Cloud AND a console RID affiliated, so probably a dispatch related group.
That's just my observations from processing the data. If I was you, I'd leave DSD running on the control channels for a while longer and then process through the data, in the same way, to see what else you can discover from patterns emerging.
  • Osceola County.zip
batdude
Moderator
your post is EXACTLY why I put up the data... I just don't have time (or really the inclination!) to do it.... as I also do not live in Osceola County - but I do live next door.
thanks for doing that!
doug
batdude
Moderator
just curious - has anyone copied ANY voice traffic on the 700 side of the 48E Osceola system?
All I see in DSD+ are failed radio authentications.... I do not think I have ever caught an actual voice call on this site of the system... anyone else?
(the 1.1 Enc Group calls in the window below are from the 800mhz side of their system - Site 1.1)
batdude
Moderator
here is today's list of unknowns on the 48E system.
today on the 003 TG, the units were all called "Enforcement". I suspect this is parking enforcement, but could be building/code enforcement too.... don't know.
TG ID (decimal), # hits, timestamp (keep in mind # hits is >TOTAL< not just today)
3, 1003, 2020/10/06 15:02, "Enforcement (?)"
5, 9, 2020/10/06 14:39, ""
14, 121, 2020/10/06 14:02, ""
22, 3, 2020/10/06 11:23, ""
29, 544, 2020/10/06 14:05, ""
33, 22, 2020/10/06 15:02, ""
39, 960, 2020/10/06 11:22, ""
42, 162, 2020/10/06 11:28, ""
44, 1161, 2020/10/06 15:11, ""
46, 4287, 2020/10/06 15:11, ""
47, 198, 2020/10/06 15:13, ""
50, 700, 2020/10/06 12:22, ""
51, 759, 2020/10/06 15:13, ""
53, 3, 2020/10/06 11:33, ""
57, 1607, 2020/10/06 14:51, ""
65, 188, 2020/10/06 9:54, ""
81, 24071, 2020/10/06 15:10, ""
83, 3, 2020/10/06 14:23, ""
85, 729, 2020/10/06 13:20, "OCSO Surveillance?"
87, 13, 2020/10/06 14:57, ""
91, 791, 2020/10/06 12:15, "Osceola ER?"
109, 5, 2020/10/06 11:30, ""
111, 3824, 2020/10/06 15:08, ""
113, 7, 2020/10/06 14:27, ""
129, 1010, 2020/10/06 14:57, ""
131, 6775, 2020/10/06 15:08, ""
135, 2547, 2020/10/06 12:27, ""
141, 3431, 2020/10/06 15:12, ""
145, 1174, 2020/10/06 13:29, ""
151, 1405, 2020/10/06 14:59, ""
153, 16297, 2020/10/06 15:13, "OCSO Jail ??"
157, 108, 2020/10/06 12:07, ""
169, 950, 2020/10/06 10:37, ""
177, 170, 2020/10/06 10:21, ""
183, 2264, 2020/10/06 14:52, "OCSO LE Net ?"
185, 194, 2020/10/06 14:33, ""
189, 109, 2020/10/06 15:02, ""
201, 4942, 2020/10/06 14:03, ""
202, 4835, 2020/10/06 14:54, ""
203, 2750, 2020/10/06 13:05, ""
204, 122, 2020/10/06 14:54, ""
207, 18360, 2020/10/06 14:55, ""
209, 763, 2020/10/06 13:55, ""
211, 11, 2020/10/06 13:52, ""
221, 505, 2020/10/06 14:14, ""
223, 100, 2020/10/06 14:21, ""
243, 11721, 2020/10/06 15:11, "Osceola Jail?"
245, 62, 2020/10/06 14:31, ""
255, 103, 2020/10/06 15:04, ""
276, 213, 2020/10/06 14:30, ""
278, 10, 2020/10/06 10:23, ""
280, 632, 2020/10/06 10:23, ""
299, 761, 2020/10/06 10:05, ""
307, 368, 2020/10/06 13:13, ""
309, 3455, 2020/10/06 13:19, ""
313, 9687, 2020/10/06 13:43, ""
318, 975, 2020/10/06 14:56, ""
325, 491, 2020/10/06 14:43, ""
339, 541, 2020/10/06 14:17, ""
347, 7, 2020/10/06 11:25, ""
361, 1559, 2020/10/06 13:18, ""
381, 1569, 2020/10/06 14:49, ""
394, 87, 2020/10/06 10:51, ""
395, 188, 2020/10/06 14:02, ""
397, 1583, 2020/10/06 15:13, ""
417, 476, 2020/10/06 14:36, ""
425, 475, 2020/10/06 15:07, ""
jcardani
Orlando, FL & Ocean City, NJ
Hi Batdude,
These are what I have from the list above, hope it helps!
Joe
33, 22, 2020/10/06 15:02, "OSCO TTY West"
39, 960, 2020/10/06 11:22, "Mosquito Control"
47, 198, 2020/10/06 15:13, "Roads and Bridges"
51, 759, 2020/10/06 15:13, "OSCO Car-to-Car"
53, 3, 2020/10/06 11:33, "Fleet Maintenance"
65, 188, 2020/10/06 9:54, "OSCO Special Ops"
81, 24071, 2020/10/06 15:10, "OSCO TTY East"
83, 3, 2020/10/06 14:23, "Inter-Ops 9"
85, 729, 2020/10/06 13:20, "Inter-Ops 5"
87, 13, 2020/10/06 14:57, "Inter-Ops 6"
91, 791, 2020/10/06 12:15, "Medical Director"
109, 5, 2020/10/06 11:30, "OSCO Civil Division"
111, 3824, 2020/10/06 15:08, "OSCO Court Security"
113, 7, 2020/10/06 14:27, "County Net"
129, 1010, 2020/10/06 14:57, "OSCO Tac 1"
131, 6775, 2020/10/06 15:08, "County Courts"
145, 1174, 2020/10/06 13:29, "OSCO Tac 2"
151, 1405, 2020/10/06 14:59, "County Jail Maintenance Control"
153, 16297, 2020/10/06 15:13, "County Jail Main"
157, 108, 2020/10/06 12:07, "County Judicial Support Services"
169, 950, 2020/10/06 10:37, "County Roads and Bridges Flag 4"
177, 170, 2020/10/06 10:21, "OCIB 1" (Osceola County Investigations Bureau)
183, 2264, 2020/10/06 14:52, "County LE Net"
185, 194, 2020/10/06 14:33, "County Fire Net"
189, 109, 2020/10/06 15:02, " County Hailing"
201, 4942, 2020/10/06 14:03, "KPD Tac 2"
202, 4835, 2020/10/06 14:54, "KPD unknown"
203, 2750, 2020/10/06 13:05, "KPD Tac 3"
204, 122, 2020/10/06 14:54, "KPD "
207, 18360, 2020/10/06 14:55, "KPD TTY"
209, 763, 2020/10/06 13:55, "KPD Patrol West"
211, 11, 2020/10/06 13:52, "KPD Tac 4"
223, 100, 2020/10/06 14:21, "KPD Car-to-Car"
245, 62, 2020/10/06 14:31, "Kissimmee Airport Ops."
255, 103, 2020/10/06 15:04, "Kissimmee Sanitation"
307, 368, 2020/10/06 13:13, "SCPD Dispatch"
309, 3455, 2020/10/06 13:19, "SCPD Tac 1"
313, 9687, 2020/10/06 13:43, "SCPD Tac 3"
394, 87, 2020/10/06 10:51, "Osceola County Schools Maint B"
395, 188, 2020/10/06 14:02, "Osceola County Schools "
397, 1583, 2020/10/06 15:13, "Osceola County Schools"
batdude
Moderator
joe, please submit these as inputs to the system and i'll process them --- just cut and paste the whole list and i'll sort them out.
awesome input - TYVM!
doug
batdude
Moderator
FYI, 325 is most certainly a St Cloud fire rescue TG. Just caught a Rescue unit coming off training and back to the station.
batdude
Moderator
WIth Joe's help, the list of Unknown user TalkGroups on the Osceola system got a lot smaller. I left TG 397 on here - we are pretty sure it's related to the schools/school board - but don't know exactly what it's used for.
Here is my current unknown list:
TG ID # hits timestamp
5, 9, 2020/10/08 5:45, ""
19, 1, 2020/10/08 1:07, ""
29, 731, 2020/10/08 5:52, ""
44, 1161, 2020/10/08 6:20, ""
46, 4979, 2020/10/08 1:27, ""
57, 1653, 2020/10/08 5:49, ""
135, 2547, 2020/10/07 13:45, ""
191, 27, 2020/10/07 8:25, ""
204, 123, 2020/10/07 0:23, ""
221, 505, 2020/10/08 1:40, ""
274, 470, 2020/10/07 16:23, ""
276, 345, 2020/10/07 13:46, ""
280, 632, 2020/10/07 10:16, ""
299, 914, 2020/10/08 3:08, ""
315, 10, 2020/10/07 14:18, ""
318, 984, 2020/10/07 15:07, ""
326, 24, 2020/10/08 6:14, ""
327, 2, 2020/10/08 3:00, ""
329, 3, 2020/10/07 16:44, ""
339, 572, 2020/10/08 5:10, ""
361, 1629, 2020/10/07 16:56, ""
363, 22, 2020/10/07 17:28, ""
381, 1592, 2020/10/07 15:25, ""
397, 1588, 2020/10/08 3:37, ""
415, 11, 2020/10/07 19:59, ""
417, 531, 2020/10/08 5:57, ""
425, 834, 2020/10/07 21:04, ""
batdude
Moderator
here is a updated unknown list for today - groups labeled with "suspected" have been narrowed down based on Radio IDs seen using that particular group. TG243 is another strange one - it's most certainly a jail of some sort, but it is out of sequence from the other Jail talkgroups. TG326 is most certainly an EMS>Hospital group, but I've not been able to copy which facility it is.
; Osceola County
5, 10, 2020/10/11 6:08, ""
8, 102, 2020/10/09 8:00, ""
14, 121, 2020/10/08 22:16, ""
18, 12, 2020/10/09 10:58, ""
29, 732, 2020/10/10 16:47, "Suspected Multi-Tac OCSO KPD SCPD"
42, 178, 2020/10/09 16:10, "Suspected OCSO"
44, 1161, 2020/10/11 6:31, "Suspected OCSO"
46, 6011, 2020/10/11 9:45, "Suspected OCSO"
48, 12, 2020/10/06 17:51, "Suspected OCSO"
57, 1747, 2020/10/11 2:49, ""
69, 683, 2020/10/09 14:37, "community center?"
72, 129, 2020/10/07 11:13, ""
97, 6, 2020/10/08 8:27, ""
98, 37, 2020/10/10 16:22, ""
135, 2852, 2020/10/11 2:27, "Suspected OCSO"
141, 3905, 2020/10/09 16:10, ""
163, 1667, 2020/10/07 14:04, ""
165, 771, 2020/10/07 11:04, ""
191, 27, 2020/10/09 16:37, ""
193, 278, 2020/10/10 7:20, ""
221, 505, 2020/10/09 9:44, "Supected OCSO"
243, 13856, 2020/10/11 10:20, "Osceola Jail?"
276, 345, 2020/10/09 13:56, ""
287, 13698, 2020/10/11 10:02, "[Trouble 287] Trouble 287"
293, 5167, 2020/10/11 9:56, "[Station 24] Station 24"
299, 1001, 2020/10/11 7:25, ""
318, 1005, 2020/10/09 15:50, ""
326, 76, 2020/10/11 9:52, ""
332, 4709, 2020/10/07 16:15, "Utilitity ??"
339, 719, 2020/10/09 15:52, ""
347, 7, 2020/10/11 8:59, "Suspected SCPD"
381, 1597, 2020/10/10 4:59, ""
415, 75, 2020/10/10 7:02, ""
417, 580, 2020/10/11 9:14, ""
425, 843, 2020/10/11 9:01, ""
batdude
Moderator
i am still trying to figure out TG 293. This is in the dB as "STATION 24" - but the comms I have heard so far don't really lead you to think it's utilities.
if you monitor this system, please plug this TG in and take a listen - it's active at all hours of the night/day.
Current list of Unknown TGs -
TGid # Hits Timestamp
1, 7, 2020/11/10 12:45,
4, 2, 2020/08/14 1:20,
5, 12, 2020/11/28 12:44,
7, 5, 2020/11/11 5:50,
8, 106, 2020/11/20 13:42,
10, 2, 2020/11/11 15:27,
13, 48, 2020/11/21 9:12,
14, 121, 2020/10/21 10:13,
18, 12, 2020/11/21 17:32,
22, 3, 2020/10/07 18:12,
26, 2, 2020/11/28 13:11,
29, 792, 2020/11/15 15:48,
42, 381, 2020/11/15 12:15,
44, 3093, 2020/11/28 14:04,
46, 6015, 2020/11/28 13:33,
48, 12, 2020/11/21 7:11,
50, 700, 2020/10/15 20:55,
52, 6, 2020/11/10 11:30,
57, 1906, 2020/11/21 15:30,
69, 684, 2020/11/21 9:44,
97, 71, 2020/11/11 16:31,
98, 37, 2020/10/21 10:44,
107, 356, 2020/11/11 19:48,
135, 3116, 2020/11/30 6:11,
141, 4141, 2020/11/21 8:49,
143, 5, 2020/11/10 12:11,
155, 7, 2020/11/21 10:25,
163, 1668, 2020/11/10 10:43,
165, 877, 2020/11/10 10:43,
171, 169, 2020/07/04 19:05,
187, 2, 2020/11/10 16:53,
191, 29, 2020/10/13 13:09,
193, 549, 2020/11/21 10:28,
197, 2, 2020/11/11 17:58,
199, 8, 2020/11/11 6:53,
204, 128, 2020/11/08 8:59,
213, 52, 2020/10/21 10:18,
217, 84, 2020/08/11 16:13,
221, 506, 2020/11/21 17:00,
241, 4, 2020/11/11 10:33,
276, 345, 2020/10/16 18:36,
278, 258, 2020/11/10 16:13,
280, 660, 2020/11/10 16:38,
289, 51, 2020/11/15 11:57,
297, 292, 2020/06/01 19:54,
298, 6, 2020/10/21 10:48,
299, 1272, 2020/11/28 15:57,
302, 2, 2020/05/01 16:48,
318, 1248, 2020/11/10 15:46,
326, 194, 2020/11/30 6:20,
327, 3, 2020/11/11 15:52,
329, 3, 2020/11/01 17:56,
331, 2, 2020/10/21 7:12,
334, 1315, 2020/08/01 16:55,
336, 2, 2020/08/01 16:55,
337, 2, 2020/10/09 7:46,
339, 984, 2020/11/15 11:14,
347, 7, 2020/11/21 16:00,
361, 1770, 2020/11/21 16:13,
363, 22, 2020/11/11 12:37,
381, 1787, 2020/11/10 18:31,
398, 2, 2020/06/30 6:12,
400, 2, 2020/07/09 9:44,
415, 109, 2020/11/30 5:29,
417, 741, 2020/11/30 4:52,
421, 24, 2020/08/24 14:12,
425, 2170, 2020/11/21 12:18,
426, 4, 2020/06/30 6:27,
