OSHP assistance
Hello! I know enough about programming and the frequencies, but can someone please help me on how to program my scanner to listen to OSHP? I have a Uniden BCD325P2, which I have already upgraded to “ProVoice”, “DMR/MotoTRBO”, and “NXDN”. I live on the South/West side of Columbus, OH. I cannot figure out how to configure my scanner to receive anything on the OSHP signal/channel (I know they are on the MARCS side but I have no clue how to configure my scanner to obtain a signal from that channel, let alone from the OSHP side of the radio). Please explain it to me like I’m a beginner, it would be very much appreciated. Thank you in advance!
belvdr
No longer interested in living
I believe you're in a simulcast area, and will have a tough time getting your unit to listen well in that environment.
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
None of these will benefit you with regards to listening to OSHP. As mentioned by the poster above me, the issue at hand is most likely simulcast distortion. In simplest terms, most scanners can't cope with many different towers in close proximity to one another transmitting the same signal on the same frequency at the same time without locking up, stuttering and missing transmissions. There are a number of workarounds mentioned in the wiki I linked but they work in very few cases, rarely in a large metropolitan area like Columbus. If I were you I'd trade in the 325p2 and pick up an SDS100. The difference in performance on simulcast systems will be night and day. You can ask for more money with all 3 upgrades installed if you decide to sell it
16b
Central Ohio
As others have mentioned, the MARCS sites that cover your area are simulcast, which means that your scanner will not be able to decode the transmissions very well, resulting in choppy or non-existent audio most of the time.
Since you are on the southwest side of town, there is a possible workaround that *might* help you. The Darby site, which is near West Jefferson, is not simulcast (it is a standalone site), and you might be able to hear it from your location. This site almost certainly isn't going to carry all of the OSP talkgroups used in Central Ohio, but you will probably at least be able to hear the West Jeff post on it.
I don't know anything about your particular scanner; you're going to have to read up on programming a trunked system. The simplest thing to do would probably be to program the Darby site as a standalone trunked system. The frequencies for the Darby site are listed on the MARCS database page, but to save you the trouble of searching for them I am pasting them below:
1 (1)063 (3F)Darby (West Jefferson)Madison769.80625770.75625771.38125774.08125c851.1375851.3875851.7375
852.0875852.9375c853.425c
If you are more south than west, you could try the Orient site instead. It is also standalone (not simulcast) as far as I know.
1 (1)009 (9)OrientPickaway769.30625769.75625771.10625c774.83125c851.700852.1375852.400
852.6625854.6375
N9JCQ
Lake Barrington, IL
For what it's worth, when I visit family in Columbus proper, I have used my 325P2 with ease to listen to the MARCS system. It's all about your location to the various simulcast towers.
